trans. lines
top trans.line does it go in top rad.hole,and bottom trans to bottom rad,or does it matter.(350 trans)thanks
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears 70 nova 5.3,350 trans 80 z28 350,350,trans,bought new 03 cat. 06 gmc swb ext cab |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: trans. lines
I dont think it matters at all, the rad cooler is just a hose in a tank.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: trans. lines
Ya probably does not matter
Re: trans. lines
thanks guys
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: trans. lines
The trans cooler would be more efficient if the trans fluid flowed from the trans to the top port on the trans cooler. Then from the lower port of the cooler, back to the trans.
Fabricate till you "puke"
Re: trans. lines
It probably doesnt matter, but from the factory....its pressure into the bottom of the cooler, & return to the trans from the top. Same deal on an added auxillary.....pressure into the bottom of the factory cooler, out the top & into the bottom of the auxillary, out the top to the trans. The FACTORY did it this way, so there must be a reason? crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
