harness question
am going to put a 5.3 in my 94 silverado. But was wondering if the motor will run using the factory computer or if i need the one that belongs to that motor.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: harness question
you need the one that goes with the motor, also you will need to have the VATS taken off, vehicle Anti-Theft System before it will run more than 3 seconds.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 03-17-2011 at 04:14 PM. |
ok will the factory fuel pump work for this? and any other info or advice on what all ill need to do.
I dont think it will, the 94 had the old LT motor in there and I believe it required lower fuel pressure similar to the GEN I motors, you need one that can supply 55-58 PSI constantly. if you have one that pushes more, then a fuel pressure regulator will be needed.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
is there a certain year motor that is higher horse? or they basically the same?
ok thanks
