Old 03-17-2011, 07:07 PM   #1
Bigo Serge
Header Option
Hey Guys,
I'm looking to buy some headers that will work with my LQ4 motor without hanging too low. I have a 3/5 drop on my 72 cheyenne, and don't want to worry about them hitting the speed bumps.
I was looking at DT headers, but they aren't ready with the big tubes. I came across some schoenfeld headers. http://www.schoenfeldheaders.com/LS1-TRUCK.htm
These headers come with a 1 3/4 primary, the DT headers do not.
Has anyone used these headers??
Thanks for your input.
Pick'em up, lay'em down, Oh Yeahhh
Last edited by Bigo Serge; 03-20-2011 at 05:49 PM. Reason: Added the size of the primary tubes.
Bigo Serge is offline   Reply With Quote
Old 03-18-2011, 05:45 AM   #2
67C10BUB
67C10BUB's Avatar
Re: Header Option
I went with the DT headers and they fit perfectly. I wouldn't rule them out if I were you.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 03-18-2011, 09:52 AM   #3
harnalien
TruckincrazY
harnalien's Avatar
Re: Header Option
Originally Posted by Bigo Serge View Post
Hey Guys,
Those look nice with a good price. I can't tell for sure if they'd fit my 2wd '84. Hopefully someone posts some experience.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 03-20-2011, 11:03 AM   #4
camarossrulz
Re: Header Option
prob a stupid question but will headers from a 98-02 camaro work in a 72 with a ls1? just wondering because i can get a set for nearly nothing
1972 C-10 short bed, 2wd, 350(ls1 coming soon)
1969 camaro ss, 496 stoker, 4sp
2009 crew cab,duramax 2500hd 4x4, lifted (sold)
2008 Daytona Charger, Hemi Orange, 07 C6 Z06
2005 suburban, 2002 grand prix gt
2005 grizzly, 2004 R1
camarossrulz is offline   Reply With Quote
Old 03-20-2011, 08:01 PM   #5
Super73
Super73's Avatar
Re: Header Option
I am running Edelbrock headers for the 98-02 F-bodies in mine. But, my motor is set as far back as possible. The passanger coil pack just about touches the firewall (maybe 1/16" away).
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-20-2011, 10:23 PM   #6
shrunken66stroker
shrunken66stroker's Avatar
Re: Header Option
Can you throw up a pic Super73. I'd like to see how they look. Thanks
shrunken66stroker is offline   Reply With Quote
Old 03-20-2011, 11:29 PM   #7
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Header Option
I have hooker Super Comp 64-72 lsx swap chevelle headers in mine
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-21-2011, 01:41 AM   #8
Super73
Super73's Avatar
Re: Header Option
This is when I first put it together in Feb/07.. No tubes were dented. But before I put it all together (slip fit collector) I did put a piece of pipe inside each primary tube and moved them over a little so it would clear the lower section of the frame rail.
Old 03-21-2011, 06:22 AM   #9
camarossrulz
Re: Header Option
looks good, thanks for the pics
Old 03-21-2011, 08:51 PM   #10
bark
Re: Header Option
hey those look great, did you mod them at all? also how low do they hang?
and do you have a part number handy, I want some for my 76
thanks
bark is offline   Reply With Quote
Old 03-22-2011, 09:51 PM   #11
52 Rat
52 Rat's Avatar
Re: Header Option
I would like a full length header but I can't find a set for a 47-54 Chevy AD with a LS set up. I am running a lq4 6.0. I have a new set of Hooker Super Comp block hugger but rather have a long tube header. Any advise is greatly appreciated.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 03-23-2011, 01:30 AM   #12
flamingbig10
6.0 powered square
Re: Header Option
Bark the headers part # 2289-1HKR. with a 4l80e it will require, trimming on fly wheel cover and the passenger side ear on trans missions and its close to the but I'll get some kind of heat wrap for the starter and the factory plug wires don't fit so I'm going to try some msds, the headers have clearance on the frame and they hang above the bottom of the frame
Aaron
Old 03-23-2011, 08:41 PM   #13
bark
Re: Header Option
awesome you ROCK... thanks for the info
Old 03-23-2011, 08:49 PM   #14
52 Rat
52 Rat's Avatar
Re: Header Option
Do you think they would fit a 52 frame? I can't find a full length header for my truck.
Old 03-23-2011, 11:40 PM   #15
Bigo Serge
Re: Header Option
I just bought a pair of Doug Thorleys headers for hella cheap....$$495 delivered!!!
http://www.dougthorley.com/
Part number THY-324Y-C, "PROMO CODE DT"
Thanks for everyones input, greatly appreciated!
