Old 03-17-2011, 08:00 PM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up Speed Hut GPS
Well I ordered my speed o and Tach for the truck. I ordered the 4" speedo GPS and the 3 3/8 tach to go in the middle. I'll use one of my own fuel gauges and buy all new oil, volts and water. Going to buy the little 2" gauges at O-Rileys when I need them.
Anybody out there have a new Ampmeter?
I'm going to keep the dash I have now since it has all the factory goodies in it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-17-2011, 08:04 PM   #2
mikey531
mikey531's Avatar
Re: Speed Hut GPS
Subscribed ! I am very interested in how it works out as I want to do the same thing this fall. Good luck !
mikey531 is offline   Reply With Quote
Old 03-17-2011, 08:27 PM   #3
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Speed Hut GPS
Well it will be a little while since I have to get all the parts together. I have a couple of old dashes I may do a mockup on before buying a new one.
Old 03-17-2011, 09:04 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Speed Hut GPS
Glad to see you are getting your install off the ground Andy. I am going to post a link to my install for the folks that read this thread, to give them a little more insight on the GPS speedo.
http://67-72chevytrucks.com/vboard/s...d.php?t=421745
LockDoc
Leon
Old 03-17-2011, 09:21 PM   #5
Andy4639
Old member
Andy4639's Avatar
LockDoc
Thanks Doc, I'm going to need all the help I can get on this one maybe. I hope to getter done by the Goof meet (April) but I don't know! I was going with all Speed Hut gauges but after seeing all the ones O-Riley has I figured they would be just as easy to use and don't have to worry about ordering them. All of them should be a basic bolt in and wire up. The oil should be nothing but hooking it back up to the line. Volt meter is just moving it into the dash instead of under it. Leave the ampmeter and water alone.I may need a ampmeter and water gauge so I don't have to rob them out of the orignal dash.
Old 03-17-2011, 09:38 PM   #6
LockDoc
LockDoc's Avatar
Re: Speed Hut GPS
I have some extra gauges. If you can't find any down your way let me know.
LockDoc
Leon
Old 03-17-2011, 09:42 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Speed Hut GPS
Thanks, I may need to get some from you. I get all my stuff out and see what I do and don't have.
Old 03-22-2011, 07:42 AM   #8
Andy4639
Old member
Andy4639's Avatar
I got some of my old dashes out and found I have all the factory guages I need and a brand new circuit board for a factory Tach. I bought it years ago in case mine didn't work. I will need a new lens though for the dash maybe. I may just cut up one of the old ones I have. I have a old dash outer skin I painted years ago that I'm going to use as a geanee pig.
Hope the gauges show up this week while I'm gone. I'll start posting pictures next week I hope. Keep your fingers crossed Doc. This should be fun!
Old 03-22-2011, 11:05 AM   #9
LockDoc
LockDoc's Avatar
Re: Speed Hut GPS
I don't think you will run into any major problems but if you do post 'em up... Good luck!
LockDoc
Leon
Old 04-01-2011, 12:29 AM   #10
Andy4639
Old member
Andy4639's Avatar
Well after several weeks of waiting they showed up today!!! Been 2 weeks. I played with them today just looking at what they will look like. I got the 4" speedo and the 3 3/8 Tach.
1st is the gauges.
Speedo:
Tach:
Here is a mockup in a old cluster. I just wanted to get a idea of how they will fit. I think they fit good. I may end up buying the rest of them.
I have to decide which way to go. Going to O-Rialleys in the AM to see what they have to offer in the small bottom guages.
Old 04-01-2011, 09:14 AM   #11
LockDoc
LockDoc's Avatar
Re: Speed Hut GPS
Lookin' good so far. Yeah, if you can get the other ones to match that would be killer....
LockDoc
Leon
Old 04-01-2011, 11:31 AM   #12
Andy4639
Old member
Andy4639's Avatar
Yea, I think that is going to be the way to go. The gas guage looks out of place. I really didn't want to do all that wiring though. I was planning on the regular circuit panel working most of it.
I was surprised that the new gauges fit inside the cluster with no mods as far as the back panel.
Old 04-01-2011, 04:40 PM   #13
LockDoc
LockDoc's Avatar
Re: Speed Hut GPS
That makes it nice for sure. The less mods you have to do the better...
LockDoc
Leon
Old 04-01-2011, 06:58 PM   #14
Andy4639
Old member
Andy4639's Avatar
Question Re: Speed Hut GPS
Got to have a circuit board for a non tach dash along with a lens for the same. I'll have to cutout the tach and speedo area so the speedhut stuff will work. Then decide on the rest after I get that done. Anybody have something they want to get rid of?
Old 07-27-2011, 12:45 PM   #15
Andy4639
Old member
Andy4639's Avatar
Cool Re: Speed Hut GPS
I know this thread is a little behind. Just haven't had time for the install. Just ordered the new dash, lens and printed circuit. I hope to work on it next week when my parts get here.
Going with all mechanical gauges except for the stock gas guage. Everything else will be mechanical!
Old 07-30-2011, 07:45 PM   #16
Andy4639
Old member
Andy4639's Avatar
Wink Re: Speed Hut GPS
Well I guess I'm putting in another order to SpeedHut for the 2 1/16" water, oil, volts and air/fuel mixture guages. I was going with just generic gauges but have changed my mind.
Old 07-30-2011, 10:29 PM   #17
LockDoc
LockDoc's Avatar
Re: Speed Hut GPS
Might as well get them all alike..... I think I am going to get a full set for the '70 when I get that far.
LockDoc
Leon
Old 07-31-2011, 05:20 AM   #18
Andy4639
Old member
Andy4639's Avatar
Yea,
I been playing with it some the past few evenings after work. I just don't think the mixing of the gauges would look to good. I'm also going to order the wiring harness for 8 gauges to make all the connection cleaner and simpler.
I'm going to call tomorrow and order them along with asking if I can get a 3" are 4"gas gauge to match.
I got the new dash and printed circuit and lens the other day. So it's just a matter of getting the gauges all now. I have a couple of ?'s though about the fuel / air gauge that I hope they can answer to.
Old 08-01-2011, 09:09 PM   #19
Andy4639
Old member
Andy4639's Avatar
I ordered the 2 1/16" volt, oil, fuel/air, gas and water guages today got the wiring harness to connect all the lights of them together to make it one simple hookup and the Gas is 3 3/8" to go back in the regular spot!
I hope to work on it next week after returning home from the beach.
Mine is white numbers that glow red at night. Muscle! Red pointer!
http://www.speedhut.com/custom_gauge...number-820.htm
Old 08-01-2011, 09:44 PM   #20
LockDoc
LockDoc's Avatar
Re: Speed Hut GPS
That should work. keep us posted on the install...
LockDoc
Leon
Old 08-01-2011, 10:07 PM   #21
Andy4639
Old member
Andy4639's Avatar
I will.
I told them to hold the order until next week after I get back home. They said they would. I'll call them next Tuesday and have it sent out. I should be home by then! Can't wait to see them installed. I plan to just tie into the wire connection on the harness. I ordered the new circuit board and lens but want need either one now. Oh well. I have it if I ever need it. I hope I can get the oil sendor and the cable for the transmission figured out by then.
Old 08-17-2011, 08:33 PM   #22
Andy4639
Old member
Andy4639's Avatar
Talking Re: Speed Hut GPS
Another update. The order is suppose to ship tomorrow they said. Because I speacial ordered the 3 3/8" fuel guage it took a little longer. I called today and was told this. Hope to have them next week.
I will have the factory looking guages in all the right spots with the air/fuel mixture guage in the vacume spot.
Once I get the guages I will start looking into a radio harness plug to use for all the wires.
Old 08-17-2011, 11:27 PM   #23
LockDoc
LockDoc's Avatar
Re: Speed Hut GPS
Good luck on the install... It should look great!
LockDoc
Leon
Old 08-18-2011, 01:47 AM   #24
Andy4639
Old member
Andy4639's Avatar
Yea I sure hope so. I got the dash and lens for a factory guage setup and now don't need any of it. Going to try and keep the factory harness in tach so if I ever go back the factory stuff it will work. I'll need a nice shematic of the harness so I can pull 12 volts and all the lights out of it. The only thing I have to figure out is how to do my high beam indicator light. I guess I will drill a hole over the speedo and put a small bulb in it.
Old 08-19-2011, 04:13 AM   #25
Andy4639
Old member
Andy4639's Avatar
I got a tracking number so maybe I'll see them Saturday! You think!
