03-17-2011, 09:18 PM | #1 |
WTB gauge cluster shell that had clock
WTB gauge cluster shell or complete gauge cluster that had a clock with no broken mounting points.
TIA Travis Tucker Posted via Mobile Device
77 Blazer 2wd 72 Blazer 2wd 72 C10 Suburban 2wd 71 C10 Suburban 2wd |
03-17-2011, 10:24 PM | #2 |
Re: WTB gauge cluster shell that had clock
All you need to do is cut a couple holes in the back for the wires to go thru, don't really need a new cluster...Mounting tabs are there already.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
03-17-2011, 10:36 PM | #3 |
My blazer is in shop right now getting the floor boards replaced so i cant see my old cluster. So the clock doesnt need the metal clips like the other gauges do to hold it in place?
03-17-2011, 11:38 PM | #4 |
The clock has a stand alone wiring harness that runs to a constant 12v source. You can make your own harness os use the harness that comes with th clock if you buy just a clock . I would get a later model quartz clock since they work better.
Frank
Born and proudly residing in a Red State ! |
03-18-2011, 12:07 AM | #5 |
Im looking at another cluster shell that I have and I see what your saying is that the clock just bolts in like the other gauges do. Thanks for the help, I have a good shel that i can use then.
