03-18-2011, 01:49 AM | #1 |
Need a litle help with wiring the starter
I put a 700r4 in my 65 and therefore had to replace the starter flywheel etc. I'm trying to wire it back up and I can't remember what goes where. Thx
03-18-2011, 02:56 AM | #2 |
Justified!
Re: Need a litle help with wiring the starter
well, if I remember correctly,
POS (+) Cable from battery and fusible link to large post on starter. purple wire from key start to small post. there may be a item in the FAQ on this, I'll have to look...
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny |
03-19-2011, 02:32 AM | #3 |
I couldnt remember if there was one or two wires besides the battery cable that went to the starter.
03-19-2011, 10:19 AM | #4 |
What kind of distributor? Points type has yellow wire on post closest to the motor. Purple wire on outside post. Hei distributor has no yellow wire hooked up.
03-19-2011, 11:35 AM | #5 |
The start wire goes to the small post on the engine side of the main terminal. (closest to the engine).
03-19-2011, 03:04 PM | #6 |
The "R" terminal is resistor bypass (wire to Dist.) and of course the "S" terminal is the purple wire......
03-21-2011, 04:11 PM | #7 |
thx fellas. I can only have so much fun raising and lowering the bags on my truck for all my friends in my shop so I decided to get it running.
03-21-2011, 09:57 PM | #8 |
K, I've got the purple wire going to the s terminal and the from the hei distributor i have the battery wiring going to the fuse block for power and i still got no power. What am i missing?
Posted via Mobile Device |
03-21-2011, 09:58 PM | #9 |
