Chevy Only Tx
Dropmember / power rack / steering joints
Does anyone have install pics for a unisteer power rack install with unisteer steering joints on a 60-66 with factory steering colum? Ive been searching but all I can find is manual racks with a 2 piece shaft and I have a power rack with a 1 piece shaft with 2 joints. Thanks !!!!!
Chevy Only Tx......... |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Dropmember / power rack / steering joints
I think there are a few in Delmo's Blackbird thread.
http://67-72chevytrucks.com/vboard/s...=444600&page=7
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-18-2011 at 10:22 AM. |
This one has a manual rack, like you mentioned, but the concept is the same, and the pinion shaft lengths are nearly identical. This one also shows the mod to the column end to accept the DD joint.
http://67-72chevytrucks.com/vboard/s...=406070&page=4
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Chevy Only Tx
I did it!!!
![]() Posted via Mobile Device
Looks great!
Did you have to pull the steering column up side the cab a little to connect it all? Or is there enough movement in the joints to make the connections on each end?
Chevy Only Tx
I just let it sit how it was, centered the steering wheel, then started mockup from the lower joint that is attached to the rack, took some measurements on the shaft, then made a double d on the factory/cut shaft. Put on joint then got them to the angle that I wanted then trimmed the supplied shaft. Worked out good! Hope I answered your Q!!! That is my step by step pretty much.
Thanks for the reply.
You answered my questions. I assume your headers/manifolds will clear also?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-19-2011 at 11:25 PM. |
Chevy Only Tx
I mocked up a set of full lengths that I had on prior to the dropmember. Had to mock up fully inflated cause the header would be lower than the truck... lol... I'm gonna have to ask someone else that has the same setup as me about headers. Probably gonna be block huggers or mid length chevelle headers.
![]() Join Date: Feb 2003
I shortened a 3 speed column about an inch and it worked perfect with 2 joints. i'll get a pic up for ya.
