Bent Frame
My frames a little bent up. Truck drove straight, panels looked fairly lined up.
Wasn’t discovered untell I began dismantling. Im thinking I need some frame work done. Front rails inch off...drive line off center...bubble in the frame...lots of shims front alignment... Id appreciate some opinions please |
Re: Bent Frame
I had some that were worse, but a trip to the frame shop took care of them. What you have IMHO is easily fixable by a qualified frame shop.
Just my $0.02 Dano
![]() ![]() It ain't yours, if you didn't build it! |
Roadtrip!
![]() Join Date: Feb 2003
Re: Bent Frame
Something isn't quite right. Now is the time to put it on a rack and get some gauges hanging off of it. Then you will know for sure.
Option 2, if it went down the road fine, body panels line up allright and you aren't chewing up tires, you could live with it if you want to save some money.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: Bent Frame
Dano,
What did you pay? When the repair was made was it a roller? Im not sure at what point shouls i take it in. Cheaper when its a bare frame? Last edited by Rich916; 03-18-2011 at 12:16 PM. |
Re: Bent Frame
bring it to me and I can put it on my frame machine. Oops it is a long drive for you, anyone with a rack can take care of that problem. You will need the front and rear suspension on body panels are not important. Jim
Re: Bent Frame
driveshafts are rarely perfectly centered from the factory . more noticable especialy if it is lowered with out an adjustable panhard bar or sagging old springs
Re: Bent Frame
This was during the 90's and the early 2k's, but the range was $250 - $500. All the frames were picked up by the shop and delivered when completed. All of them were bare frames. I always went to bare frame for my restos and had to always get the frames checked before I could bring myself to start building up a truck. The shops always told me that rollers were OK, because they could also check for bent a-arms, trailing arms, and front crossmembers etc.
Re: Bent Frame
Thanks Jim
