Old 03-18-2011, 02:19 PM   #1
tdave00
Restoring a 68 SWB
tdave00's Avatar
Wood Floor Modification - Hidden Bolts
I was noticing how my wood bed bolts to the frame and came up with a way to keep from having those bolts come all the way through the wood. With the way that I have done it the bolts will now be hidden.
I bought six 1/2 inch x 2 1/2 inch grade 8 bolts, washers, nuts, and locknuts. I centered the bolts in the crossmember holes and tightened them down with a nut on each side.
Then I welded both sides of the nut to the underside of the crossmember
You can see here how the bolt will tighten down all the crossmembers from underneath. Not sure if anyone has done this already. Just thought I would share.
tdave00 is offline   Reply With Quote
Old 03-18-2011, 03:16 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Wood Floor Modification - Hidden Bolts
yep, thats how I did mine, but I didnt weld them. I too didnt want them through the wood.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-18-2011, 11:43 PM   #3
tdave00
Restoring a 68 SWB
tdave00's Avatar
I guess in hindsight I didn't have to weld them. I could of just used a smaller length bolt and slid it through the bottom support of the crossmember. Then just use another nut and washer on the bottom side of frame mount to tighten it down. Duh!
hidden bolts, wood floor
