Old 03-20-2003, 04:05 PM   #1
Custom 68
Custom 68's Avatar
removing dash pad
Hey all I am trying to remove my dash pad from my 68. Is it glued on or what? I have removed the screws but it doesnt want to budge. Thanks
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-20-2003, 04:18 PM   #2
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
There's some nuts on the backside, about 5 or 6, if you remove your glovebox liner you'll be able to get at the ones on the right side. pull your dash panel to get at the left side. There's one thats hard to get at up above the radio. Hope that helps
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
Old 03-20-2003, 07:53 PM   #3
weasel29gm
SLOW BUT SURE,BUT CLOSER
Yep 1971 covered it right the one over the radio is hard unless you pull the radio.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 03-20-2003, 08:25 PM   #4
Nova_Cobra64
Nova_Cobra64's Avatar
Just so you don't have to mess around seeing what fits, it is held on by 3/8" speed nuts. I just loosened the left half on mine to puy my home made tach mount under it. It is much easier to take off than put on.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 03-20-2003, 09:00 PM   #5
Custom 68
Custom 68's Avatar
cool thanks all. I will try it later
Dave
