What has to be Done ? I have the sides but a floor is impossible to find here. Wood is a option but the stuff is really $$$$$.
Help me I need a floor soon. the cab and clip are omost ready for primer. Mario. ![]() ![]()
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
72MARIO, I'll be finished tonight & can get the measurments on the long steel floor I'm working on. If I can get a camera by then, I'll click some pics when I make the cuts. I'm prob going to try & buy a mig-welder asap to get this & my crossmember done.
Any info in particular your looking for?
Is it just 2 simple cut's ? I never had a box so I have no idea how it goes together. I am going to get a LWB floor tubs and head board next friday. Any help would be great.
![]() Join Date: Jun 2002
Take your stock long bed floor, cut 12" off the front of the floor, and 8" off the rear, but take the aft 8" approx. 4" fwd. from the aft edge, because you will have to weld the rear cross member/ aft end of floor back to the remaning floor. That way you can save the end of the ribs.
See attached pic. Before welding, bolt the bed sides to the floor, then bolt the aft 4" peice to the bed sides (rear pillars) (4 locations each side), that way you can make minor adjustments if needed. I hope this helps. It's hard to explain, but it is not that hard to do.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
Thank's I think I will figure it out.
You say to cut 12 off the front first then cut only 4" from the back ? Kinda lost there.... Could you Please try and explain it again ?
Scribe a line 4" from the rear lip of the floor. Scribe a second line 12" from the rear lip of the floor. The 2 scribe lines indicate the 8" you will remove.
When cutting like Kid described you will need to drill new holes to be able to bolt the header panel & bedsides on. The front will also not have the factory tapered appearance (in case this matters to you).
Thanks for clearifying my post SCOTI, as you said, you will need to drill holes thru floor to bolt the header panel on, the bed sides align with existing holes except for the fwd. 1 hole. Drilling new holes for the header panel was easier than welding another 5' seam.
