Help - Do I need a power steering control valve?
So I am putting together a power steering system from AutoZone and am buying the following parts.
Steering Gear Power Steering Pump Crank Pulley Brackets Pitman Arm Brackets Belt but they show something called a power steering control valve that is $170 - do I need this too? |
Re: Help - Do I need a power steering control valve?
The valve is in your power steering box with the setup that you are looking at.
The 67 power steering used a power steering control valve with the "assist" cylinder. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
