Old 03-19-2011, 01:07 AM   #1
Newold65
Angry Question on Rims??
First of all just want to say thank you to all those who post on this site. You guys are a wealth of knowledge. Now my question is this I've got a 1965 chevrolet 6 hole drum that I want to put a 2005 chevrolet rim on. Only problems are the center does not clear, and the lug nuts I need to use to attach the center caps don't fit either. I've heard I can purchase a wheel adapter but don't know where to get one or even exactly what it is I'm asking for. I know they aren't 20's but for 100$ I think they'll do.Thanks in advance.
Newold65 is offline   Reply With Quote
Old 03-19-2011, 11:32 AM   #2
scotts62
One day...
scotts62's Avatar
Re: Question on Rims??
Im running into that on my '92 and will have to get wheel adapters to get them to work. They are around $150 from wheel shops for 1" adapters.
Scott
93 crew cab build
Project 62
Old 03-19-2011, 12:58 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Im guessing you will need the adapters to help with the offset of the newer rims?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-19-2011, 11:04 PM   #4
scotts62
One day...
scotts62's Avatar
Yep. Im about to the conclusion to just order ones that fit verses trying to make mine work.
Scott
93 crew cab build
Project 62
Old 03-20-2011, 12:29 AM   #5
Real_McCoy
Real_McCoy's Avatar
I think the 4X4 rims might work, but the stock studs are only 7/16" which will not fit the newer lugs. You could have your axles and drums drilled out to get them to fit, maybe. I am thinking that I would rather spend the same money for some nice after-market rims that are designed to fit than go through all the headache and expense for a look that I am not as thrilled with.
Daniel
66 Chevy C10 LWB
Support our troops!
Real_McCoy is offline   Reply With Quote
Old 03-20-2011, 03:21 AM   #6
blackedoutharley
If you're worried about being able to utilize the oem center cap on those wheels that is held on with a captive plastic nut that attaches to the lug nuts just buy these lug nuts.
http://www.ezaccessory.com/GM_7_16_E..._p/98-0022.htm
They are identical to the OEM lugs that came with the wheels except they are 7/16" x 20 vs. 14mm x1.50.
blackedoutharley is offline   Reply With Quote
Old 03-20-2011, 01:43 PM   #7
Newold65
Hey guys thanks alot for all the suggestions I think I'm going to go with the wheel adapters found em up in lubbock for about 100$
Old 03-20-2011, 10:17 PM   #8
scotts62
One day...
scotts62's Avatar
Thats not bad.. was that new or used?
Scott
93 crew cab build
Project 62
