Getting ready to start wiring
OK, I'm at the point where I need to mount the new E-Z Wiring Harness Fuse block. I know it will go on the front firewall in the upper left section. Since I've never wired a vehicle before I'l need pleant of pointers.
The kit I have is the E-Z Wiring 21 circuit and Dolphin Gauges. http://ezwiring.com/wiring_harness.html 18 FUSES 21 CIRCUIT Radio, Coil, Dome Light, Backup/Cruise, Horn, Cigarette Lighter, Fuel Pump, AC/Heat, Radio, Turn Signal, Horn, ACC, Wiper, Gauges, Hazard, Fan, Power Window, Power Door Locks, Brake, Headlights. I know I will have a few extra wires that will not be used like power door locks, fuel pump, etc. and expect to have to bundle these and tuck them under the dash. Any ideas along those line would be good to know. What scares me is that I'd like to learn some proper tech about termination connections and the such. I' have Jolly's information on running relays (which I will do for brighter headlights) and the proper way to use connectors and I've read Alan Horvath's tips (he's got to do it all over again becasue painter really messed him up) . BUT there is nothing quite like trying all this new stuff for yourself. Anybody who has done this please chime in. I'm the type of person who will read something several times before trying just to make sure I have it right (less screwups that way.) Thanks Jake Groby
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 03-19-2011 at 10:44 AM. |
1 thing at a time is progress.
Re: Getting ready to start wiring
I would offer some help, but I haven't done mine yet. What I can do is move this thread to the electrical section. Maybe you will receive more answers there. LMK
Alan
Philippians 2:14-16 |
Resistance is Futile
Are you doing a stock rewire or a new updated version? I think the factory routing was strange, but it mite have had to do with the assembly.
Regardless, I would start with the routing of the harness and eliminate anything not being used right off. Just do a section at a time and then figure out your connections. What are you planning to use for connections? Original style, weather pack, or just crimp style sleeves?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
I don't really know how to correctly answer your question. I suppose I have to follow "stock"? ideas?
http://s1299.photobucket.com/user/jb...23904108567829 |
#5 | |
Again, my trucks are also all V8. Maybe the sixers are different. If you are restoring, then I would assume you would be using a stock routing path. I just pulled out a harness I picked up on C/L and started sorting it out. It may go in my 'burb and I'm thinking of using weather packs to do all the connections. It will not be stock! ![]()
i used the same wiring harness in my 63 its a very easy setup i just cut the wires that i wasnt using and left about a foot just in case i got a hair up my ass to do some more **** in my truck the good thing about that setup is everything is marked so all u gotta do is read the wiring and attach it to where it is supposed to go
Just here to tinker
![]() Join Date: Jun 2008
Hey Jake, as long as you have solid connections and use quality terminals and heat shrink, I think you'll be fine. I know some guys prefer to solder wires and never use butt splices and the like and then just heat shrink over the solder joint.
I am sure I'm not just speaking for myself when I say we wouldn't mind seeing some more pictures of that beautiful cab, so take some pics along the way, will ya? ![]()
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
I've set up an album showing all the reassembly process - Enjoy.
http://rides.webshots.com/album/579894970vydbSl Jake
Hollister, CA.
![]() Join Date: Sep 2006
I agree with Protrash ... as far as the output to engine compartment.
If you remember my the 'rock-a-billy', I actually ran the harness out the grommet, and thru the fender well to help 'hide' the harness, but this is not neccesary. I recommend running everything to there locations, following cleaner routes than stock, waiting till the end to tie strap. (as you might add something or change your mind) One step at a time ... it is really easier than it looks !! ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Break it down into sections, route everything, then terminate only those sections your comfy with the routing and that are secure. This worked best for me, course I am a very simple minded guy, and I can only think of......what were we talking about again?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
