Old 03-19-2011, 01:12 PM   #1
justinburnett
justinburnett's Avatar
front main seal
Need to replace the front main crankshaft seal on a 1970s 400sbc. Have the timing cover off already. When I pulled the old seal, there is a metal ring part in the front that I thought would just pop out but it seems attached to the timing cover so all that came out was the rubber inside ring. I have a new seal but this one looks like it should tap into a straight hole, but what I have is a little channel with a lip no the front and the seal won't fit. THis all seems wrong. Should I pry off the metal ring on the front of the timing cover or is there some trick to doing this tIat I'm not getting?
Thanks.
justinburnett is offline   Reply With Quote
