03-19-2011, 02:54 PM | #1 |
73 Front crossmemeber swap under my 69
Ok guys so i have a 69 3/4 ton long bed that I am planning on baggin. Last saturday i picked up a full front crossmember with 5 lug disc brakes, power steering and the works. I guess ill do a build thread but i need some help for now. I got the A-arms tore down for the most part but i need to get the cross shafts out so i can have the a arm powder coated and replace the bushings. I have heard there is a tool but any help on where to get one or how you would get this out?
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388 |
03-19-2011, 03:41 PM | #2 |
Re: 73 Front crossmemeber swap under my 69
interested also
1969 Chevy c20(Miss Hackjob) |
03-19-2011, 04:20 PM | #3 |
Just a car guy
I cleaned mine as best as I could and took them to a machine shop to have poly bushings installed.
They have to be pressed.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
03-19-2011, 11:59 PM | #4 |
You will need a hydraulic press and several pipes etc of varied lengths. It takes time and if you are not careful, you can bend the arms.......
I would take it to a capable shop and shell out the coin.... |
