MadMan
Need help putting 2002 Z06 brakes on a 81 C-10
I want to use everything and anything I can off of this donor car... I would love to use the Z06 brake setup but I'm afraid of running up against a wall. And I know it will narrow my wheel choices with the oversized calibers and rotors. If any of you guys have successfully completed this swap please post some pics and give some info....PLEASE....PRETTY PLEASE...
81" Shortbed C10 Full Restoration underway, who needs a budget?? LS Pro Touring Build |
BMW & ASE Master Certified
Re: Need help putting 2002 Z06 brakes on a 81 C-10
Ive done the rear conversion, not the front... yet.
![]() with the Corvette rotors, a stock ralley barley makes contact with the caliper bracket.... a 1/8 spacer would eliminate the problem. You could also swap to a corvette, non directional vein rotor but you would have to space the caliper accordingly. http://67-72chevytrucks.com/vboard/s...=415021&page=2 clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
MadMan
Thanks for the info... this is exactly the kind of feedback i'm looking for. What about the big rotors up front?? I want to install all 4 rotors and calibers
Happy to be here
![]() Join Date: Mar 2000
Contact way2lo2. If anyone here knows how, he does.
It wont narrow your wheel choice, it will open it up ALOT. There are way more wheels for the 5x4.75 lug pattern then there is the 5x5 pattern. If I were you, I would contact Tobin at Kore3. He will be able to help you out with everything.
http://www.kore3.com/ |
just put the hole rear irs in your truck and swap out front suspension!I did that on my 67 I just used older vet stuff but the second gen irs is easer to work with and it makes for a much better ride!
![]() ![]() ![]() 67 c10 swb build in progress 70 c10 lwb driver pending parts for drastic overhaul 70 c20 lwb parts truck for above mentioned drastic overhaul 71 k20 lwb building for off road use and towing |
way2lo2
![]() Join Date: Sep 2004
If you mean Z06 brakes like this, I can help as long as you want drop spindles, if you don't want drop spindles, I can still help but you'll have to send me your spindles to do it.
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote. 216 481-5219 office 216 481-4240 fax 216 789-1647 mobile Way2Lo2@aol.com <----also my paypal http://www.hubgarage.com/mygarage/way2Lo2 |
Would love some more information about this for my 86 but i already have dropped spindles and i was wondering if i could use the brakes off my Z06 when i upgrade to the newer Z06 brakes.
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy |
way2lo2
any c5 or c6 brake option will work as long you use the calipers and rotors from the same brake option. Our brackets will work with Mcgauphys spindles but they will need to be machined which we can do for you or we have already machined spindles in stock.
way2lo2
machined spindle and brackets
#11 | |
MadMan
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks....
Drag Racer
wow thats cool, so does that mean our bolt pattern changes or is it still 5x5 for us half ton 2wd guys
Zach Hall 1983 Chevy C10 R/T: .194 60': 2.322 330: 6.379 1/8: 9.803 MPH: 71.37 1000: 12.781 1/4: 15.314 MPH: 88.79 |
#13 |
18 Till I Die
Im Watchin this...Will thes work for us 15" Torque Thrust Guys?.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
#14 | |
MadMan
#15 |
Happy to be here
Not even close. I think they will require at least a 18" wheel.
#16 |
Im sure they dont. The rears are only a 12" rotor and the factory steel wheel barley fits... actually touches the caliper mounting bracket a little. The only way the rears would fit no prob is if I redid the spacer for the caliper mount and use a camaro rotor... but no way on the fronts... maybe if you ran skinnies... but skinnies and squares isnt practical,
clint
#17 |
MadMan
brake upgrade will be a must with the new engine... time to start putting parts together
#18 |
MadMan
I have 2002 C5 slotted and drilled rotors and calibers.. I will need the caliber brackets too right?? I already had drop spindles.. So will I still need anything machined??
I'm still trying to figure out whats all needed for the rear conversion too
#19 | |
Clint Posted via Mobile Device
#20 |
MadMan
how much for the rear kit?????
#21 |
MadMan
Ok.. this is what I ended up with
![]() 1. Cadillac Eldorado rear caliper 2. Flebay rear disc conversion bracket kit 3. Had axles machined to fit the rear rotors 4. Flebay slot/drilled Cadillac rear rotor 5. OEM front caliper (new) 6. C10 slot/drilled front rotor 7. Rockauto front and rear brake hoses 8. All new custom bent brake lines
#22 |
MadMan
Looks better than expected.
#23 |
MadMan
I ended up using the cadillac rear and OEM C10 front for ease of parts. It was much easier this way. I was getting frustrated trying to complete the other setup
#24 |
MadMan
My front rotors should be in today. I recieved a set of 6lug rotors the 1st time
#25 |
MadMan
This kit does keep the ebrake.. that was important
