03-19-2011, 05:54 PM | #1 |
Cluster Removal Question
I want to take out my gages to fix some burned out bulbs and try and diagnose my non-working fuel gage. I was wondering how the headlight and wiper switches come out? They seem to be holding in the bezel. It looks like the switches have a trim piece that screws in holding the bezel in, but I don't know how the knobs come off. Thanks in advance for the help!
03-19-2011, 05:59 PM | #2 |
454 MAKES IT ROAR
Re: Cluster Removal Question
Wiper knob has a small screw at the base, the headlight switch has a small button to push in to release it you will access that by reaching up under your dash feel around the back of the swithch till you find it.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
03-19-2011, 06:13 PM | #3 |
Grandpa in the rustmobile...
Yeah Wiper knob has a very small screw on it
Lights have a small button at the top of the switch, you'll have to push in button and wiggle/pull on switch.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
03-19-2011, 07:02 PM | #4 |
Thanks you guys, I got them off easy with your info. The oil pressure line is another story though...
03-19-2011, 07:07 PM | #5 |
cut da sum beech lol
Nah, I dunno maybe let it soak in PB blaster overnight, with some heat tomorow? lol
03-19-2011, 07:16 PM | #6 |
It should come off pretty easy, its a little tiny brass tubing nut. Use a tube nut wrench to keep from stripping it if you have one. Did you check to make sure the wire for the fuel guage is plugged into the fuse box. It won't work without it. I kept kicking mine out is how I know. Good luck.
03-19-2011, 09:28 PM | #7 |
its all about the +6 inches
it takes more effort to remove the panel than it does to replace the bulbs with it installed. You can also see most of the circuit on the back side too.
Whats the fuel guage do? Most of those isses end up being either a bad float or a damaged wire from the tank. |
03-19-2011, 11:39 PM | #8 | |
03-20-2011, 01:17 AM | #9 |
Msgt USAF Ret
Have a look.
http://www.6066gmcguy.org/Electrical-02.htm
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
04-19-2011, 02:43 PM | #10 |
how about the choke knob how does that come off?
04-19-2011, 02:48 PM | #11 |
there is no stock chrome knob... what does it do?
04-19-2011, 03:08 PM | #12 |
the Choke knob on the right side of the cluster is what i'm trying to figure it it pulls out there is no screw on the the knob it self
04-19-2011, 03:15 PM | #13 |
also behind every knob there is a nut that is threaded towards the Dash much you remove those as well?
04-19-2011, 09:02 PM | #14 |
More Cowbell....
Gas gauge reading way past full = open circuit
Gas gauge reading below empty = grounded circuit
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
04-19-2011, 09:07 PM | #15 |
saving this
1969 Chevy c20(Miss Hackjob) |
