lowering question
hey guys, got a couple questions for ya. got a 66 1/2 ton 2wd that im wanting to lower a couple inches. just gonna do a quick cheap job on it. im thinkin bout just cutting the front coils. any idea how many coils i would have to chop off for about 3 inches of drop? and for the rear i have been told that i can just use 3 inch drop blocks, will those work right in these trucks? thanks for any help
Resistance is Futile
Re: lowering question
Drop blocks can be inserted after taking apart and replacing the rear U-bolts. Usually come in as a kit.
I believe the general rule is 1'' per loop. I cut a set of 1'' drop srings 1 coil and ended up roughly 2'' down. You may want to start with one coil and see how you end up. All springs are different and no telling what mite happen on old springs.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
CLASSIX Truck Club
If your looking for cheap, Do this. Pull the front coils out and cut 1 1/2 from the front. The rear you can pull out also and cut 2 coils. The back can be done as easy as taking out the top bolt, raising the frame and cutting the coils while still in the truck. Not the best way but it works.
Standard blocks will not work (unless you have leaf springs).
There is a thread on how to make them. Hard part is longer U bolts. IIRC it was posted by TX Firefighter. Rear springs are pigtailed at each end, so "I" would not cut. Thread is in the FAQ's http://67-72chevytrucks.com/vboard/s...d.php?t=196457 Last edited by astrochimp; 03-20-2011 at 01:01 PM. Reason: link |
thanks for the replies everybody. and thank you very much for the link astro, it really helped me out
I cut out 2 full coils in the front of my 66 and removed the rears completely. However I live in Cali and the roads are bumpy as hell here so it rides a lil rough but looks cool. Also my frame sits abut 5 inches off the ground and speed bumps are a pain.
so no springs at all in the rear? is it just sitting on the bump stops now?
#8 | |
here is a not so clear pic |
hmmm, may be worth a try just to see how i like it. not like i cant just put the springs back in if i dont like it. i had thought about doing that before but wasnt real sure how good it would work. and it doesnt have to ride like a cadilac or anything. i rarely drive the old truck. plus if it rode that good then it wouldnt feel like a truck anymore lol
#10 | |
Many people have gone with stock 97- 02(?) Jeep TJ (wrangler) rear coils to swap out the stock rear coils in the rear end. IIRC, gives a 3" drop and much better ride than the bumpstops.
![]() Check your local 4x4 websites - many have gotten theirs from $free to $20 for a pair. |
hey LILJP when you dropped your truck that far did you have to replace the tracking arm with an adjustable one or are you still using the stock one with no problems?
#13 |
Everything is stock with no problems. I am running 15" stock rims with remington g78x15 tires. I cant feel any pulling nor have I seen any camber wear.
#14 |
thanks man, i really appreciate it. i think i may just go that route with it then. im like you, not really worried bout how it rides as long as it looks good while its jarring the teeth out of my head.
![]() Last edited by jaybyrd66; 03-22-2011 at 12:01 AM. |
#15 |
no problem. Let me know it you got anymore ?s
#16 |
will do man, and thanks again. I hope to get started on it tomorrow. ill try to post some pics of it as soon as i can.
If you cant shoot it, Race it, Sleep with it or eat it. down here in Tennessee we just don't need it. |
#17 |
I'll try to get some pics up in the next day or two. Its been raining and my whitewalls hate the rain
#18 |
well i got the front lowered today, cut 2 coils off and she is sitting on the bump stops now, will work on the back end this weekend hopefully. here is a couple before and after shots
before after
#19 | |
Just here to tinker
![]() Join Date: Jun 2008
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
#20 | |
Rollin' Old Skool
![]() btw, the front looks great |
#21 |
Time out.
In your original thread you said you wanted to lower the back of your truck 3". If you take the springs out (something that I would never even consider) you’re dropping more like 7-8". I’m sorry but I don’t agree with LILJP’s66 on this one. Personally I think it would be dangerous and most likely illegal to run with no rear springs. If you hit big enough of a bump it’s going to lift off the bump stops and slam back down. On bumpy turns the rear-end will try to skip out on you. It’s cool being low but you got to be safe. I would take the advice of some of the replies above and try the Jeep TJ springs. There's lots of info on lowering your truck on this site including some on the TJ spings. Do some searching and reading. My truck has had the springs cut (not the best thing to do). I’m going to re-do the suspension (at the same stance) with the use of springs, spindles and blocks.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#22 |
CLASSIX Truck Club
[QUOTE=jaybyrd66;4572475]well i got the front lowered today, cut 2 coils off and she is sitting on the bump stops now, will work on the back end this weekend hopefully. here is a couple before and after shots
You have to take the bump stop out. And with a sawzall, cut the bracket that holds it in place. It will give you like 3"s of more clearance. I did that to a few trucks, and worked just fine. NEVER did it bottom out. Unless you go off road or something. |
#23 | |
so you cut your rear springs? how much did you cut off them? ive decided not to take them out completely. just wandering how low i can go by cutting them.
#24 |
It was done by the PO. He didn't say how much he took off, but he did say he re-pigtailed them. It's a liveable ride but I'm going to upgrade.
#25 |
I haven't had any bad experience as of yet and I think the pan-hard bar would stop the rear end from sliding. My frame is fastened to the lower arms so it doesn't jump up when I hit bumps. Hopefully I will be putting bags in shortly.
