03-20-2003, 07:32 PM | #1 |
driving is in my blood
for sale or trade: rebuilt 350
Guys, Ive decided to sell the spare 350 sitting in my backyard. Heres the low down on it:
The block was bored .060" It was standerd when I got it, but I messed up the bore [faulty measuring tools the first time] and had to go .060" The heads had a valve job done and all valvesprings were tested. The heads are stock 882 heads. New stock cam+lifters was installed New cast flat top, 4 valve relief pistons [9:1 with the 882's 76cc chambers] Rebuilt stock cast crank, I belive turned 10/10 New stock rings, timing chain and bearings New gaskets Performer intake. This is a "iffy" part. It was well used and given to me for free. It was free because in the back where the water passages hit the manifold [with no where to go] it was badly corroded. I sanded it down and filled and smoothed the bad area with JB weld. It should hold fine, but its somthing you should know. It has re-used pushrods and rocker arms. I also have some stock truck exaust manifolds without air tubes on it. I checked all the clearences myself with plasti guage. Its been sitting in my backyard for a few years now, under a RV shed. It has surface rust, but very light. I havent pulled it apart, so I dont know what it looks like inside. I am selling it as-is. Ive never fired it up, never even cranked it over with a starter. I will sell it out right, or for the right price part it out. Also will trade for big block parts.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
03-21-2003, 07:23 PM | #2 |
Oh,you can't buy that new
I know you have the stuff to test it on a stand . that engine will be fine. open the spark plug holes and shoot some ATF in the holes before you fire it . prelube with distributor tool and your ready. the JB weld is better than the aluminum against water . i repair all types of alum. manifold pitting problems with it. well not JB weld per say some Nuclear grade stuff i get at work that costs more but is the same and then they trow it away when it gets old. DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. |
03-21-2003, 07:43 PM | #3 |
yup, I have a HEI distributor on there, some nice non-smog tube manifolds, flywheel and balancer, all from good ol dave! But Im keeping the balancer and distributor, they work good
03-21-2003, 10:41 PM | #4 |
I suggest you let them go with the engine.
I have more
