Old 03-19-2011, 08:18 PM   #1
Fesser
Fesser's Avatar
Power steering pump brackets question
Is there any difference on power steering pump brackets on two wheel drives and four wheel drives. I have two setups here that I believe are first gen. smallblock setups. One is cast and seems more compact, the other is cast and stamped. Just want to be sure either can be used on a k5.
Fesser is offline   Reply With Quote
Old 03-23-2011, 12:17 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Power steering pump brackets question
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-23-2011, 05:53 PM   #3
Fesser
Fesser's Avatar
May have answered my own question. I tried both types on the Blazer and they both seem to clear everything.
Old 03-23-2011, 07:21 PM   #4
JimKshortstep4x4
They both will work. The pulley location may be different between the two setups so check it out. The all cast brackets go with the cast crank pulleys.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-23-2011, 08:52 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've seen more than a few of the steel ones crack but never a cast one. I've been told by my buddy, GM guru and long time Chevy dealer parts guy, that this was a running change made to alleviate the cracking issue.
