Old 03-20-2011, 07:55 AM   #1
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Question Floor mat & underlayment
Did trucks that came with the rubber floor mat also have a heavy tar like sheet material under that and a white foam pad under that? Not sure if the foam is original. ??
Here's a pic showing the foam, I had already pulled up the tar sheet material which sat on top of it.
Thanks,
Bob
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 03-20-2011, 08:23 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Floor mat & underlayment
yep. its under the longhorn's mat
Old 03-20-2011, 06:19 PM   #3
eagleuh1
eagleuh1's Avatar
68 C20 had the tar mat on the metal floor, white foam on top of that, then rubber mat. looks to be the same foam as mine.
eagleuh1 is offline   Reply With Quote
Old 03-20-2011, 06:32 PM   #4
bobs409
bobs409's Avatar
I think that would make more sense. Maybe someone had mine out and put back in wrong?
Anyone else?
Bob
Old 03-20-2011, 06:38 PM   #5
Yukon 400
My suburban came that way too rubber, foam, and tar on the metal
1953 Chevy 6400 Truck - 2 Ton Pickup Project - 5.9 CTD, 6 Sp Allison, Air Ride, 22.5 Wheels
1952 Chevy 6400 Truck - Looking for a direction in life
Yukon 400 is offline   Reply With Quote
Old 03-21-2011, 08:30 AM   #6
bobs409
bobs409's Avatar
Thanks, that's the way it's going back together then. I haven't found the foam yet but the other items are available.
Bob
Old 03-21-2011, 08:59 AM   #7
RenoKeene
Florida Edition
RenoKeene's Avatar
Same with my 72 Custom Camper. Rubber mat was made by Uniroyal.
Your wrecker is brutally cool.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 03-21-2011, 09:41 PM   #8
Yukon 400
For some reason that foam reminds me a lot of the underlayment that is used for laminated wood flooring, i'm not too sure if it's exactly the same but it looks awfully similar.
Old 03-21-2011, 10:15 PM   #9
sameyrasmea72
sameyrasmea72's Avatar
From what I can tell the older trucks like the 67's had the tar right on the metal floor. That is why you nearly have to use a chizel to remove it sometimes. On all the 72"s i have seen the foam is under the tar which is good because you can lift up the foam and remove it in tact and reuse it if possible.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 03-21-2011, 10:24 PM   #10
sameyrasmea72
Original 72 w/tar on top of foam.
72 Cheyenne Super
Old 03-22-2011, 01:35 AM   #11
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Dang you guys made me go out in the dark but...walla!
Floor, stock sound deadener (tar-mat),
foam and rubber mat on top. Stock 1968 C-10
The mat is not glued to the floor but seems to
have an oil-impregnated paper coating on both
sides; not sticky at all. Almost resembles an
expansion joint used in concrete work, but thin.
ETsC10 is offline   Reply With Quote
Old 03-22-2011, 01:48 AM   #12
Tyler212
My 68 was the same as ETsC10 and if you find a foam or insulator let me know I'm lookin for a replacement at the moment too. Best for the money I can find is : https://www.shopatron.com/products/p...er=14720/681.0
or
https://www.shopatron.com/products/p...er=14620/681.0
1968 Chevy C10
1998 Suburban
My Truck
Tyler212 is offline   Reply With Quote
Old 03-22-2011, 11:40 AM   #13
arkansas
My 71 had the mat, tar, then the white foam on the metal. My dad bought the truck in 1972 and the mat had not been pulled out before I took it out. As evidence of this, under the foam I found a brand new plastic indicator plate for the key switch that the guy at the factory must have dropped. It was very neatly imbedded in the white foam next to the tranny hump.
arkansas is offline   Reply With Quote
Old 03-22-2011, 06:15 PM   #14
bobs409
bobs409's Avatar
Wow, now we have it both ways.
Guess I'll take my pick as to how I want to put it back.
Bob
