Old 03-20-2003, 08:51 PM   #1
purple69
purple69's Avatar
factory bucket seats?
where do they bolt in floor thanks scott
purple69 is offline   Reply With Quote
Old 03-20-2003, 09:18 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Are these 67-68 style or 69-72 style? If 67-68 then the frame will bolt using same holes as bench seat. If 69-72 then you need to drill holes for each seat and the console. What I did with this style is use the front outer hole used by the bench seat as guide for both driver and passenger seats, then drill the remaining holes. Reenforce with washers underneath. I'd test placement the seats before drilling. The remaining holes existing for the bench seat will go unused.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
