Old 03-20-2011, 04:50 PM   #1
JRBECK64
Behind the Seat Fuel Tank Problem
I went out to my Sons 64 Yesterday to find a major problem. I was getting in the truck when I noticed that all the paint under the fuel nozzle was bubbled up and peeling off all the way down the cab to the bottom. I will post pictures later. My Question is has anyone had this same kind of problem and if they did "Other than moving the gas tank between the Frame Rails" how did you fix it? I sure dont want this to happen again. Red Paint is expensive.
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 03-20-2011, 05:02 PM   #2
lakeroadster
Re: Behind the Seat Fuel Tank Problem
These trucks have non vented gas tanks that require a vented gas cap. If you fill the tank all the way up with gas and then park it the gas will warm up. As it warms up it volumetrically expands and if the tank is completly full it starts to leak out via the vented gas cap.
My dad had a '72 C-20 that did this everytime until we learned to not fill the tank all the way up. My job as a kid was to fill up the tank when he got home. We had a gasoline storage tank with a hand pump at our "mini-farm" and I got good at listening to the sound of the gas goin' into the trucks gas tank and knowing when to stop based on the "sound".
The only way to "fix" the tank so it won't do this would be to install a vent line that is below the gas cap height. Then you can use a non vented gas cap. The gas will then leak out of the vent line instead of the cap.
Note: Make sure the vent is located such that when you fill the truck that the gas pump nozzle extends past it. If you don't gas will run out the vent line when you fill up the gas tank.
Since the 60-66 tanks have a seperate neck that attachs to the gas tank with a rubber hose you could remove the filler neck (the neck that sticks out through the cab) and have a 1/2" vent line tig welded into it (see sketch below). Then run a 1/2" fuel line from that down and out of the cab. You'd probably have to pull the tank to get the rubber hose off the neck.
Hope that helps.
John
lakeroadster is offline   Reply With Quote
Old 03-20-2011, 07:57 PM   #3
JRBECK64
Hope that helps.
John
John,
Last night after I vented a little myself I kind of came up with that thought of putting in an expansion relief or an overflow that would work much like the overflow in a radiator. Seems like a simple fix but taking out the tank is a pain. I guess its not as much of a pain as doing bodywork over and over again. Thanks for the info and I think that is what I am going to do to fix this problem. My Sons 69 Does the same thing but not as bad so I may do the same thing to his.
JRBECK64
Old 03-20-2011, 08:05 PM   #4
JRBECK64
Hard to look at!!!
JRBECK64
Old 03-20-2011, 08:44 PM   #5
j.kirn
I did the same thing on my 64 c-60 after i painted it ,it also was red
j.kirn is offline   Reply With Quote
Old 03-20-2011, 08:53 PM   #6
lakeroadster
Originally Posted by JRBECK64 View Post
Hard to look at!!! JRBECK64
Man..... that truly sucks.... damn! Was the paint fresh? My dads truck had factory paint but the gas never messed it up?
Old 03-20-2011, 09:06 PM   #7
nachodog2
Hell yeah!!!
nachodog2's Avatar
Ouch!
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 03-20-2011, 10:06 PM   #8
JRBECK64
The paint is about a year old. Im thinking it wicked up underneath the paint under the rubber gasket that goes around the fuel neck and the cab. I am going to take a few extra steps to protect it from this ever happening again.
JRBECK64
Old 03-21-2011, 01:59 AM   #9
'63GENIII
'63GENIII's Avatar
Same thing happened to my '77 Harley. Looked as if the gas got under the clear and then it was all over. Bummed me out. I feel for ya!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 03-21-2011, 11:41 AM   #10
JRBECK64
Its all fixable and it wont happen again once i fix the problem. Sorry to hear about it happening to the Harley. I guess this is a common occurance. I am going to fix my Oldest sons 69 Long fleet because he can only put about a half a tank in without the same thing happening.
JRBECK64
Old 03-21-2011, 01:48 PM   #11
Stew64
Stew64's Avatar
This can be a common problem with straight enamel paint. Gas can eat it. If you use an acrylic paint that will usually stand up under gas spills.
1964 Longbed
Stew64 is offline   Reply With Quote
Old 03-21-2011, 02:00 PM   #12
caddyhack
caddyhack's Avatar
Would this be fixed by running a vented cap or did the vented cap cause the problem?
I wish I was rich instead of so damn good lookin!!
caddyhack is offline   Reply With Quote
Old 03-21-2011, 02:01 PM   #13
glos55
glos55's Avatar
Thanks lakeroadster! You are always quick with great information and pictures!!!!!!!!!!!!!!
glos55 is offline   Reply With Quote
Old 03-21-2011, 04:40 PM   #14
lakeroadster
The vented cap is the cause of the problem.
Old 03-21-2011, 05:58 PM   #15
astrochimp
John
You can remove & replace the hose with the tank in place. PITA, but probably easier than removing tank. IIRC I only removed hose from tank end, and pushed the neck in to the truck (bending hose to side) and installed the same.
astrochimp is offline   Reply With Quote
Old 03-21-2011, 06:10 PM   #16
JRBECK64
Stew64,
I used PPG base coat clear coat urethane. What I think happened is the gas leached under the Nozzle Gasket and it got under the clear coat and started eating from there. This Ethinol will eat through just about anything.
JRBECK64
Old 03-21-2011, 06:17 PM   #17
JRBECK64
I am going to fabricate an Overflow much like the Radiator has so this will never happen again. Once I get the Nozzle out I will create a sump in the nozzle with a drain that will empty back into the tank on the top. I have a full gas tank so I need to drain it and fill it with water and flush it several times before I try to do this so I dont blow myself up. Thanks for the Info.
JRBECK64
Old 03-21-2011, 06:36 PM   #18
lakeroadster
I don't think the return line will work. It works on a radiator because when a radiator cools down it pulls a vacuum which sucks the antifreeze in the puke tank back into the radiator. That won't happen with the gas tank. The puke tank will just fill up with gas and then you will be right back at square one.
But I may be wrong?
If you are dead set on trying it though you should be able to do the sump and the return all in the removable piece. Drain on the bottom, return on top, staggered so the return doesn't go into the drain.
That would eliminate you having to weld on the tank.
In regard to welding on the tank.... I worked at a place that repaired oil field equipment. We steam cleaned the vessels and then used a battery powered "sniffer" device on the vessel to ensure no explosive gases were present. Sometimes the vessels needed to be steamed out for hours to pass the sniff test.
Some radiator shops will do repair welds on gas tanks, might be better safe than sorry?
Old 03-22-2011, 11:24 AM   #19
JRBECK64
But I may be wrong?
Lakeroadster,
I think that I didnt exactly explain where I was going with the overflow Idea. I used the Radiator Overflow tank as the example but on this system I am going to bypass the overflow tank with a gravity feed back into the top of the tank. One of the problems these tanks have is the fact that the gas nozzle that is attached to the tank is extended into the tank instead of terminating at the tank. I believe that even when these tanks are full they are not really full to the top of the tank because of that extention into the tank. Now the question is will the pressure differential not allow the gas to flow back into the tank from the sump I am going to build on the gas nozzle. I guess only time will tell but you can bet I am going to keep a close eye on what its going to do after I implement it. Im not wasting any more red paint cause its way to expensive. Thanks for the heads up on the welding of the gas tank, and I think I might just take your advise of taking it to the local Radiator shop.
JRBECK64
Old 03-24-2011, 01:58 AM   #20
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: Behind the Seat Fuel Tank Problem
Hope that helps.
John
Hello John 1971--72 Have vented tanks its part of the smog program every 1971--72 truck i have have vents and i was told and i did it to my locking gas cap all you have to do it drill the center of the gas cap and there is your Vent i did it to my 1965 3/4 ton I never have a problem with gas leaking out its only if your tank builds up pressure So my father used a small drill bit and breached the plastic and your done
stsalvage is offline   Reply With Quote
Old 03-24-2011, 11:58 AM   #21
JRBECK64
stsalvage,
Thanks for the advice and that sounds a lot easier than what I was going to do. Can you just put a vented gas cap on it from a newer truck?
JRBECK64
Old 03-24-2011, 06:31 PM   #22
lakeroadster
If the tank already is vented, why would you want to vent the cap?
The leakage that JRBECK64 is talking about is due to the gas warming up. As it warms up it volumetrically expands and if the tank is completly full it starts to leak out via the vented gas cap.
Drilling a hole in the cap means it will again leak out of the cap in the above condition?
Think of it this way, if the tank isn't full and it builds pressure the vented cap is venting gas "fumes" not gas "liquid". JRBECK64's truck obviously was leaking liquid.
Old 03-24-2011, 06:39 PM   #23
oldtrux
oldtrux's Avatar
behind the seat fuel tank tank is a problem!
oldtrux is offline   Reply With Quote
Old 03-25-2011, 05:22 AM   #24
JRBECK64
lakeroadster,
I think I am going to try to fit my 67 GTO gas tank between the back rails and get a licence plate that will pull down so I can fill the truck from the back. I am going to take the bed off anyway to do the bodywork on the back of the cab so with it out of the way it seems that would be the time to change it out. If that works I might just do the same thing to My Sons 69 Long Fleet. Paint is a lot more expensive that a new gas tank so I think I am going to make $$$$ be my motivator. Then I have to figure out where to put the spare tire??? Neverending problems.
JRBECK64
Old 03-25-2011, 08:05 AM   #25
lakeroadster
lakeroadster,
I think I am going to try to fit my 67 GTO gas tank between the back rails and get a licence plate that will pull down so I can fill the truck from the back. JRBECK64
I understand totally. The only problem with using the license plate fill design is the gas tank will hang down very low. They are clearly visible from the side and the back of the truck. Some people don't like that look, some people don't care.
That look really bothers me so I used a 49-52 Chevy tank on my '65 for that reason, and a couuple other guys on the site here have done so too.
Check out the various types of tank installations here: The Rear Mount Gas Tank Thread
