Old 03-20-2011, 07:09 PM   #1
**grumpy**
**grumpy**'s Avatar
Oh Crap! my rearend hurts....
***EDIT...Read to new update..4-10-11..***
Or is hurt!
The 72 5-lug 12bolt I got with my truck to swap in is frozen solid...sorta.
Its been in the bed of the truck since I bought it 4wks ago. I finally took it out today and noticed instantly that the axels wouldnt turn, nor would the pinion.
So I took the cover off, and its dry as can be..with alittle rust here and there.
So I call the PO and he said he got it 15yrs ago, and its lived outside the past 5yrs.....
So I turned it on the pinion and poured 2 gallons of WD-40 into it. Figure let it set for a week and soak.
And before you ask, I had 7 gallons of WD-40 as one of the many "parting gifts" from when they closed our plant and kicked us to the curb...
Anyway, back to my sore rearend...
Any chance this can be saved????
Road Hounds
**grumpy** is offline   Reply With Quote
Old 03-20-2011, 07:20 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Oh Crap! my rearend hurts....
Its not that kinda forum.....
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-20-2011, 07:21 PM   #3
61_FL_Apache
Who Me?
Got any pics of its condition?
Steve
2001 Blazer 4D 2WD
Old 03-20-2011, 07:50 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Oh Crap! my rearend hurts....
Also you can ask some fellas over here too bud.
The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums
Engine & Drivetrain
http://67-72chevytrucks.com/vboard/f...splay.php?f=24
I'd think I would pass on that rear end if it was me. If it froze up that bad. May have to get all new parts to be on the safe side if you did continue to use it.(rebuid it) You can inspect it to see how bad it is. Inspect Axle Bearing And Race For Pitting, Corrosion, Or Wear, Inspect Axle Seal For Missing Rubber Etc. Maybe rebuildable. I'm partial to Ford 9"ers myself.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-20-2011, 08:10 PM   #5
awbrown
Does the pinion move just a bit ? is the ring gear moving slightly?? Maybe it is the brake shoes are rusted to the drums?? I ran into this a week ago on a gto rearend.. I had to torch a hole through the drum where the brake adjuster would be and cut the brake adjuster in half...then the drums came off and it turned...
awbrown is offline   Reply With Quote
Old 03-20-2011, 08:27 PM   #6
**grumpy**
**grumpy**'s Avatar
No drums or brakes on it..just backing plates and wheel cylinders. It doesnt seem to move at all.
I'll let it soak and see if it moves after a couple days.
Its not like you trip over 72 5-lug 3.08 rearends all day...I hope I can get it to work.
I assumed I would have to do axle bearings and seals, but...
Road Hounds
Old 03-20-2011, 08:34 PM   #7
**grumpy**
**grumpy**'s Avatar
Heres a pic I took after the first gallon of WD40. The white milky stuff is from bottom of the can not the rearend.
Road Hounds
Old 03-20-2011, 08:59 PM   #8
awbrown
Oooo , a posi! Good luck , I guess you could glassbead the gears and rebearing it ...
Old 03-20-2011, 10:20 PM   #9
scotts62
One day...
scotts62's Avatar
If the gears are pitted with rust it will not last long and will start stripping metal. Your best bet is to rip it apart and go through it.
Scott
93 crew cab build
Project 62
Old 03-21-2011, 01:32 AM   #10
**grumpy**
**grumpy**'s Avatar
The thing is, the gears look good. I dont see any rust or pitting on them.
Im wondering if the axle bearings are seized?
Id hate to not be able to use it. A 3.08 posi/limited slip is perfect for me.
Road Hounds
Old 03-21-2011, 06:14 AM   #11
scotts62
One day...
scotts62's Avatar
If it wont turn there is something not right, could be the bearings but hard to say.
Scott
93 crew cab build
Project 62
Old 03-21-2011, 06:32 AM   #12
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
I seem to have some new in the box parts that would help you out. Let it soak and then put a big bar between the wheel studs and see if you can break it loose.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 03-21-2011, 07:48 AM   #13
Scot_Douglas
Scot_Douglas's Avatar
Don't know how "N.E." you are in Ohio, or what's in your toolbox - but I have a decent dial indicator and in*lb wrench for when you rebuild 'er. Be happy to loan then to ya when you need them.
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 03-21-2011, 10:09 AM   #14
jchav62
1962 C-10
jchav62's Avatar
Buy and install a bearing and seal kit...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-21-2011, 05:13 PM   #15
scotts62
One day...
scotts62's Avatar
Scott
93 crew cab build
Project 62
Old 03-21-2011, 05:39 PM   #16
blackedoutharley
I agree also.... bearing and seal kit.
http://www.ringpinion.com/ProductDet...spx?ProdID=391
They offer another kit that uses Koyo bearings and is about $50 less but I prefer the Timkens used in this one.
blackedoutharley is offline   Reply With Quote
Old 03-21-2011, 05:41 PM   #17
blackedoutharley
The white milky stuff.....
This was headed in a bad direction....
Old 03-22-2011, 08:57 PM   #18
awbrown
Smile Re: Oh Crap! my rearend hurts....
Grumpy , I hate to see you stress out over this ... I can pick it up in 2 weeks when I go to columbus and then all your troubles will be over ....wink wink.. No really dont thank me ...
Old 03-23-2011, 06:39 AM   #19
63sbssbbw
UCA63
63sbssbbw's Avatar
Good score Grumpy
Definitely worth the rebuild
lol wish I could find one
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 04-10-2011, 08:20 PM   #20
**grumpy**
**grumpy**'s Avatar
Ok. New update.
So after the 3.08 posi seemed locked up, I bought a non-posi 3.73 5-lug to use.
But I hate the idea of a granny 4spd and 3.73s. It isnt much better than the 4.10s in stock rearend.
So the 3.08 soaked in 2 gallons of WD40 for over 2 weeks. And today with little effort it turns.
So I dumped the wd40 out and looked inside. No chattered teeth or anything that looks ugly.
So I dumped 2qts of synthetic motor oil...just to soak some more. After 2 hours, it spins free as can be.
So now, if I drain it again, and flush once or twice with gear oil, do you guys think I should take my chances and run it?
The 3.73 rear is nice, but Id much rather have the 3.08 posi...
Sorry for the long ramble...
Road Hounds
Old 04-10-2011, 09:21 PM   #21
blackedoutharley
If it spins freely (not exactly free but as it should with no binding) then I would install it...fill with fresh gear oil and drive it... paying close attention to any noises and such.
After about 100 miles or so pull the rear cover and inspect everything (try to do this with the rearend warmed up from use to get as much oil out as possible). If it looks good button it back up top off with fresh gear oil and go.
Maybe wait a few months and check it again?
On the other hand I would probably replace the bearings and seals just so there is one less thing to worry about.
Old 04-10-2011, 10:14 PM   #22
**grumpy**
**grumpy**'s Avatar
Yeah, I wondered about the bearings and seals too.
Thing is, its been sitting,,or should I say, standing, on the pinion for over 2 weeks, maybe 3, full to the brim with WD40.
Not a drop came out of the pinion seal or axle seals. And being wd40 is so thin, I would of thought it woulda leaked somewhere.
Im gonna let it soak in 10W40 synthetic for a few days, just going and turning it daily, then flush with gear oil.
See what happens then I guess.
Road Hounds
Old 04-11-2011, 09:15 AM   #23
Str8axle
Str8axle's Avatar
I agree!! I say install it and run it.
Ray
All my life, I've been told I'm a "Bad Influence"
Str8axle is offline   Reply With Quote
Old 04-11-2011, 09:34 AM   #24
jchav62
1962 C-10
jchav62's Avatar
Run it! I'm sure it will run with no problems, but if it does, it will let you know. I have a small feeling that those bearing may whine for a bit. If it does whine and it doesn't go away, the bearing may need replacing.
Joseph Chavez
