03-20-2011, 07:32 PM | #1 |
swapping from drums to rotors? 1965 4x4
So I have a 1965 c10 factory 4x4 with the origional "6 lug" front axle and it has drum brakes up front. I was wondering if there is a kit, OR BETTER YET a newer truck I can steal brake parts off of from the junkyard to swap mine over to disk brakes up front? Im in the middle of doing my brakes. It needs a new Master cyl. Drums. Shoes. And front hubs(cus previous owner seriously jerry rigged the hubs) and while im in there i though about swapping it over since im running 38" tires and I dont want to rearend someone on the street.. If there is a truck to steel them from. What Year, Make, and Model do I need to get the parts off of???
I wish I was rich instead of so damn good lookin!! |
03-20-2011, 11:58 PM | #2 |
Re: swapping from drums to rotors? 1965 4x4
I believe you'll have to swap the entire axle over to a disc-brake equipped axle out of a newer truck, plus match the gear ratio. I'm not aware of any drum-to-disc kits for the front on a 4x4.... ?
I have a '68 K10 with front drums, I recently acquired a disc-brake D44 out of a '76 truck for a donor. Plus the open knuckle axle has a bit tighter turning radius too. Also, you'll have to swap m/cyl and brake prop valve for the disc too. Maybe someone else will chime in with some other options...
Too Many Projects: '50 GMC '62 Nova drop-top '68 K10 '68 Chevelle SS Last edited by Permafrost; 03-21-2011 at 12:02 AM. |
03-21-2011, 12:40 AM | #3 |
Resident of Here
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
03-21-2011, 01:28 AM | #4 |
Currently Blazerless
I agree with Permafrost...best way is to find a 71 to 87 Dana 44 or 10 bolt, as long as it matches your rear ratio. On a side note the 73 up axle shafts and u joints are a little stronger...might help since your gonna be running 38s
Also the kit from Blackbirds is for an 8 lug conversion..they didnt list a kit for the 6 lug 1/2 ton axle...and I know they have some quallity stuff since I've used it myself but at 535.00 I think anyones best bet is to get away from the closed knuckle front, unless you want to keep it stock in which case you wouldnt be wanting discs anyway.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
03-26-2011, 06:32 PM | #5 | |
Still plays with trucks
A disc brake Dana-44 or 10-bolt can be had for under $100. You would be lucky to find the disc brake parts you need to convert yours for that.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
03-26-2011, 09:15 PM | #6 |
Up here you can get a D44 8 lug for 100-400 in good shape. The six lugs are even cheaper because they seem to be more abundant. I'd be looking in that direction.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
03-27-2011, 01:27 PM | #7 |
Find a Craigslist open knuckle front axle instead of sink a bunch of money into a junk one (closed knuckle).
