Whats up with this ?
After cleaning and painting the engine bay for the big block transplant this caught my eye. The VIN on the frame has the last two digits 39 ground out slightly and the next corresponding numbers 40 stamped right under the original ones. The VIN on the cab matches the 40 and does not appear to have ever been tampered with. Odd dont you think?
Re: Whats up with this ?
Could be a factory change due to a mistake. Maybe the gang holding the stamps did not get changed for this chassis, then once it was stamped and noticed it was changed. There are other stamps on the frame, not sure were. Curious what those look like.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Gearhead
I think the frame is also stamped around the front body mount area on th top of the rail (basically on the drivers side of the cab) , but I could be mistaken.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
Old Skool Club
![]() Join Date: Jun 2001
On the left frame rail, mine is stamped in the engine bay area, and underneath the cab.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Haha! GM screwed up. Must've been a Friday truck. Everyone wanted to go home and have a coolie pop.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS ![]() -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) ![]() You've gotta be able to stop and steer before you can go fast! |
Could have been a factory mistake (it sometimes happens) but absolutely should never have been ground down.
The factory requirement for repair of mistakes is that they be "X'd" out using an X stamp over the mistake and the correct digits stamped below. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-21-2011 at 11:11 AM. |
its all about the +6 inches
better than my one ton... the frame is one digit younger than the cab, and never corrected on the frame.
It's not common, but not unheard of either. It just came up on here less than 3 weeks ago |
Thanks for all the comments / opinions. What everyone has suggested is also what I was assuming / hoping. This doesn't bother me in the least just kind of adds to the uniqueness of my project. I dont want to be just like any particular style or forum just doing it the way I like. I'll get some photos up soon. Oh by the way it's a 69 swb fleetside 6cyl. 3 on the tree soon to be BB turbo 400 that i've had since 97 used to be my DD but been setting in the garage since 06. Can you say procrastinate...
#9 | |
The problem is by the time it was noticed you wouldn't have just one vehicle that was messed up - you'd have a whole line full of them. We would try to catch them all by working the line back while it was running or, if you were lucky, it happened right before lunch or a break or end of shift and you could make the repairs with the line stopped. Obviously the intent was to catch them all but it's easy to imagine one or two escaped. Longhorn - were was that particular truck built? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-22-2011 at 11:46 AM. |
#10 | |
![]() Join Date: Sep 2001
Mine was a baltimore truck.
