Old 03-20-2011, 09:44 PM   #1
Transformula
Transformula's Avatar
Question about SM465 output shafts.
Weather a 4x4 SM465 is bolted to a 205 or a 208, is the actual output shaft the same length and 10- spline? I know the adapters are different, I just need to know if I can buy a 465 from a 208 and use it with my 205?
T.Y.N Custom Works..... Because "Stock" Sucks!
1971 K 10 GMC Long Bed
1977 Formula T/A Frame off Resto-Mod
1995 FXDL Harley Low Rider
1985 C10 ShortWide 91 Burb front.
Transformula is offline   Reply With Quote
Old 03-21-2011, 12:10 AM   #2
Altec
Getcha Pull
Altec's Avatar
Re: Question about SM465 output shafts.
As far as I know all NP208 465's are 32-spline round pattern. So if you have a figure-8 style pattern case that is 10-spline the easiest option would be to find the matching tranny.
Or do what I am doing. I found a 32-spline 465 with a NP208. I'm going to use this combination until I can find a 32-spline NP205.
Edit,
A SM420 should also bolt right up to your 10-spline NP205 IIRC.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
