Old 03-20-2011, 10:21 PM   #1
oldie67
No fluid to rear brakes.
I am a newbie so bear with me. I am the new owner of my dad's 67 chevy stepside 2wd. I am having problems bleeding the rear brakes. I had to replace both wheel cylinders plus new brake shoes and I also replaced the master cylinder. I have removed all the lines from the distribution block (prop valve) and blew air through all the lines. Still no fluid. I have also tried gravity bleeding but still no fluid. I read on another thread that my valve may need to be reset. I removed the distirbution block and removed the pin from it. When I look down inside the block all I see is a bar of some sort. So how can tell if the valve needs to be reset or replaced? My brake light on the dash is not on. It only comes on when I first start the truck but then it goes out. My truck is all four wheel drum brakes. Any help would be greatly appreciated.
Thanks,
Oldie67
1967 Chevy Stepside 2WD
350 engine
T350 Tranny
600 cfm Edelbrock carb
Edelbrock Rpm camshaft and intake manifold
oldie67 is offline   Reply With Quote
Old 03-21-2011, 07:30 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: No fluid to rear brakes.
Check your rear brake hose. They like to swell shut on the inside.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 03-21-2011, 07:40 AM   #3
chuckmc8
It's alsways something.....
chuckmc8's Avatar
I agree with usmcchevy-The flex brake line hose goes from the top of the differential to the frame- these are avail at box parts stores. since u have to take the old one off anyway, remove it and take it with you to compare at the store. If it is possible to sell the wrong one, the employed at AZ and such can rise up to the task....
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 03-21-2011, 08:26 PM   #4
oldie67
Thanks for the help. I will replace the rear brake hose and let you know how it goes.
Thanks,
Oldie67
Old 03-21-2011, 08:31 PM   #5
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Did you bench bleed the master cylinder before you installed it?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 03-21-2011, 08:34 PM   #6
72 Super
72 Super's Avatar
Welcome to the board. If you replace your brake hoses and still no luck I would try another master cylinder.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 03-21-2011, 08:37 PM   #7
cdowns
cdowns's Avatar
that pin on the distribution block should NEVER be removed// to reset it you take a clamp and push it in
Old 03-23-2011, 09:29 PM   #8
oldie67
Sorry for the late response. Been working long hours.
I did blech bleed the master cylinder before installing it. I was able to get a new rear brake hose today. I will try to install it tomorrow if it doesn't rain. I appreciate all the help and support. Will keep you posted on my progress.
Old 04-03-2011, 12:10 AM   #9
oldie67
Sorry for the late update. I have not been able to work on the truck lately due to my job. I just finished replacing my rear brake hose and still NO fluid. I blew air through the lines before installing the hose. I then let it gravity bleed for about 45 minutes but still no fluid. I then hooked up my test to a ground and ran a wire from the positive side of the battery to the brake switch contact pin on the prop valve. The light came on. Does this mean that the prop valve needs to be reset. If so, how is it reset? Also my pedal goes all the way to the floor.
Thanks,
Oldie67
Old 04-03-2011, 12:55 AM   #10
cjohnson6772
cjohnson6772's Avatar
My truck is disc brakes on the front, but I've been having a similar problem. Here is what I found out after a lot of headache. The prop valve on mine at least has a port on top with the sensor for the brake light. If you remove the sensor and look down in the valve then you can see a shuttle in the valve. The shuttle needs to be in the middle. Ok well mine was always pushed to the rear. I could take the sensor out and physically move the shuttle, but the first time I would touch the pedal the shuttle moved back blocking off the rear brakes. So the problem was that I needed the shuttle in the middle to bleed the brakes, but you can't bleed the brakes without touching the pedal.....hmmm.....or can you. Get a vacuum bleader. A mechanic friend of mine had one and it fixed the problem instantly. Basically it is a vacuum pump that fits over the bleeder valve and sucks the fluid through and the air out. Just make sure and keep fluid in the master cylinder as you bleed it. Worked for me. Stops like a new truck. Good luck
cjohnson6772 is offline   Reply With Quote
Old 04-03-2011, 07:05 AM   #11
oldie67
Thanks for the info. My friend has a vaccum bleeder so I will see if I can borrow it. I will let you know how it goes.
Thanks,
Oldie67
Old 04-03-2011, 11:49 AM   #12
mbgmike
You can bench bleed it but if on vehicle you don't have to take it off. Mfg's tell you this as they deal with DIY's Most techs do not bench bleed unless new and sometimes not even then. You can disconnect the two ports and place your fingers over them. While someone slowly pushes the pedal(slowly is the key) then hook up the lines and bleed normally. It can make a mess but you use rags.
I suspect the rear hose as they do seperate as stated earlier.Brakes are pretty easy but they can be a headache at times. It really a simple system
mbgmike is offline   Reply With Quote
Old 04-03-2011, 12:12 PM   #13
oldie67
Thanks MGBMIKE,
I did bench bleed the m/c again last night. The pedal gets hard but as soon as I remove the plugs and install the lines the pedal is very spongy. I still have no fluid to the rear brakes. I am going to try and reset my prop valve today. I have also replaced the rear brake hose but still no fluid. This is my first time dealing with something like this so I apologize if I keep going over the same thing. I appreciate all the help and advice.
Thanks,
Oldie67
Old 05-07-2011, 03:08 PM   #14
oldie67
Sorry for the late update. I have been working a lot of hours at work. Just wanted to let you know that I now have brakes all around. I did a bench bleed of the master cylinder and replaced the rear brake hose and blew air through the rear lines. I now have a good pedal. Thanks to everyone for their help. I'm loving this site.
Thanks again,
Oldie67
