Old 03-20-2011, 11:08 PM   #1
zicc1835
zicc1835's Avatar
Red face Headers
can anyone tell me if headers from a 73 c-20 SB will fit in a 67 c-20 SB
zicc1835 is offline   Reply With Quote
Old 03-22-2011, 12:42 AM   #2
treveiger
treveiger's Avatar
Re: Headers
Dont take my word to heart, and hopefully somebody will chime in if im wrong but i dont see why not...
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 03-22-2011, 12:58 AM   #3
crazy longhorn
Fabricate till you "puke"
Re: Headers
Yes, they should. The only prob I can see ,is if you are running a stick in the 67 & the headers are not verified for stick shift. Also, the lip on the top rail is a tad wider on the 67.....you may need to trim a spot or 2 for clearance. The factory trimmed the frames 68-72, as they did install BB engines in some of them. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-22-2011, 06:27 PM   #4
zicc1835
zicc1835's Avatar
Re: Headers
thank you for the info it is much appreciated, the donor was a stick i will give it a whirl in a week or so and will let you guys know how i make out
Old 03-22-2011, 10:05 PM   #5
treveiger
treveiger's Avatar
Re: Headers
sounda great! best of luck.
