Old 03-20-2011, 11:58 PM   #1
mrchubz
Point me in the right direction
I have a 70 c10 long bed and the lower control arms are worn out to the point of not being able to just replace the bushings.
I am wanting to know if 73-87 lower control arms will bolt on directly or what has to be modified? I've searched and searched but I cant find any solid information on what to do?
Any help will be greatly appreciated.
mrchubz is offline   Reply With Quote
Old 03-21-2011, 12:33 AM   #2
60ratrod
yes, i do
60ratrod's Avatar
Re: Point me in the right direction
ok, take a left then at the first stop light make a right...... oh wait, not that kind of direction. anyway i don't think they fit without some modification. i would surf ebay for some used or repops, or even better some tubulars since yours are worn out
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 03-21-2011, 01:12 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Posted by member gringoloco in another thread:
Upper/lower arms will bolt on. I would use the u-bolts from the newer truck as they are a larger diameter and probably not as rusty. You will likely want to snag the brake lines off the donor truck as well to make the caliper/prop valve connections easier. Otherwise you will need adapters. Adapters will also be needed for the outer tie rods. Easy solution to this again is to snag the entire steering setup from the donor- link, inners, outers, everything. Remember you're going to five lug from six, so new wheels too...
LockDoc
Leon
Old 03-21-2011, 01:31 AM   #4
LockDoc
LockDoc's Avatar
Here is a thread that might help too...
http://67-72chevytrucks.com/vboard/s...d.php?t=317654
LockDoc
Leon
Old 03-21-2011, 11:01 PM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: Point me in the right direction
well some of these people like paying other people to work on there stuff.If you take off your upper and lower A arms can i have them there worth more then the 1973 and up front ends.reason there serviceable and that means a lot means it cheaper working on them you can take them apart at home with out a Press.Ya they for got to tell you about that.Now you have to involve a shop and they get 65.00 -- 85.00 a hour.Reason why i say this Both the upper and lower A arms Unscrew the bushing and they come apart in 3 peaces there so easy to work on if you have a Vise and big sockets and a braker bar your there and there kinda fun
the 1973 you have to Press out the joints and press them back in But be careful you don't go in cockeyed of your going out to buy another A arm you oblong that hole you will never get that joint back in there and the parts for the 1964--72 are the same they came in 1/2 all the way up to 3 ton Bobtail trucks
stsalvage is offline   Reply With Quote
Old 03-22-2011, 01:17 AM   #6
ETsC10
Hand Crafted C-10
ETsC10's Avatar
mrchubz, good advice here. First look for rebuildable cores, as 60ratrod mentioned, and
if you can't find them, follow LocDoc's links.
ETsC10 is offline   Reply With Quote
