Old 03-21-2011, 02:38 AM   #1
Dino Driver
Dino Driver's Avatar
Advice wanted, LQ9 on a 64 1/2 ton frame
I purchased the motor mounts that Early Classics sells after seeing the install pics from this board. Once I got them, trimmed the frame rails and installed them, installed the LQ9 with 4L80E tranny I found an issue. With the motor at 4 degrees and the pan of the tranny level, the centerline of the output shaft of the tranny is 5/8" over the top rail. Stan at ECE has been very helpful but is at a loss about how to solve the issue. The motor sit awesome between the rails, there is 1" clearance on the pan. What issues might I have if I tilt the motor down more to get the tranny output below the top of the frame rail. Does it need to be below? is there enough clearance for an unaltered cab?
Dino Driver is offline   Reply With Quote
Old 03-21-2011, 03:22 AM   #2
mwilliams5891
Re: Advice wanted, LQ9 on a 64 1/2 ton frame
sorry I know this doesnt help but I am interested....so subscribed.....and its nice to see someone from Oregon....
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56
-03 Mazda Protege 5
-WTB 1970 Chevelle project
mwilliams5891 is offline   Reply With Quote
Old 03-21-2011, 01:45 PM   #3
67C10BUB
67C10BUB's Avatar
I wish I could help, but I put that kit in a 67 and it fit perfectly.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 03-21-2011, 02:47 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have a 4.8 in mine and didnt have that issue, used those perches also.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-21-2011, 03:37 PM   #5
Dino Driver
Clyde, do you remember what the elevation of the tailshaft was? was it below the top of the frame rail?
Old 03-21-2011, 04:53 PM   #6
Clyde65
Clyde65's Avatar
You know what, I am stupid, I used the POL perches not the ECE perches. I am sorry!
Clyde65
Rebuild of Clyde
support our troops!
Old 03-21-2011, 09:54 PM   #7
TR65
TR65's Avatar
Dino,
The original 283 in my 65 had the crank shaft centerline 11" above the bottom of the front cross member (board clamped to the bottom of the cross member, measured up to the crank center line at the harmonic balancer).
I set my LS2 crank center line 11-5/8". At a 3 degree angle (low at back) the transmission snout is about at the center of the frame rail (but it is a T56). I have about 1/8" clearance with the cab floor but it is a low hump cab floor.
Hope this helps some.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 03-23-2011, 08:41 PM   #8
structures
structures's Avatar
Here's some measurements I took of my 4.8l 4l60e in my 65. I used the ECE mounts. My tranny pan slopes a bit to the rear, not much. I took a look at my 03 Z71 and the tranny pan slopes a bit to the rear also. Do you have any pics of your setup?
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 03-31-2011, 02:16 AM   #9
Dino Driver
I am now revisiting the 4L80 transmission. Although there is not a huge length difference, there is an overall size difference and I'm certain a 4L65 (which was origianlly behind this motor when it was in a 2003 Silverado SS) will be a better fit. From what I have gathered, the 4L70 would be even better. The 4L60, 65 and 70 all have the same dimensions but the 65 and 70 will not work where a 60 has operated because of different style of sensors.
