Metal knocking even after new shocks
So my 68 has never been lowered but the shocks were blown so when I would hit bumps it would sound like it was bottoming out somewhere around the front end suspension and the frame would be my guess. I put new shock on which helped the ride but I still get a metal knock when hitting bumps. What can cause this? I know it could be a multitude of things but I am lost. Ball joints maybe? Are there rubber pads that are supposssed to be somewhere that could be worn out? Help and thanks!
Re: Metal knocking even after new shocks
Same thing happens to me. It usually does it on gravel driveways. I think it might be my inner fenders though since there's no bolts around the wheelwells. I didn't feel like putting them in because I'm going to have to pull them to replace the fender emblems. Yeah, I'm lazy.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS ![]() -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) ![]() You've gotta be able to stop and steer before you can go fast! |
MIne sounds deeper down and deepr sounding than what you are describing.
Check your ball joints if you haven't already done so.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
![]() Join Date: Oct 2010
Instead of doin my brakes on the 68 I had to help my buddy do ball joints on his Ranger.
It did the same thing, ball joints are the best bet. |
the boat guy
ball joint, bump stop, sway bar bushings, control arm bushings....
Will do, and thanks.
loose sway bar.
oh, ok, I will definitly check that too.
have you greased balljoints tyrod ends etc???
Scrapper 1
Do you have a looseness as well when you hit a bump.the truck is all over the place.At 40 mph and above dose the truck feel loose.If so check your Rear Leaf spring bushings and if you have coil springs check your ladder bar bushings if they get lose they will bang big time
