Old 03-21-2011, 10:11 AM   #1
PLANETGETLOW
Air Shocks & PSI ??
I installed a set of Air Shocks on my sons truck and have never used a set before I'm not sure what the max PSI should be?
Seems like it starts raising around that 80-100 range but I don't want to get much higher thinkin I'll damage something.
If anybody can give me a baseline I'd appreciate it?
Minimum says 15psi
Testing says 40psi
Then it says to adjust to desired ride height but doesn't mention max. Can you max these out?
Here's a pic of these for reference:
Columbus Air-Levelizer
PLANETGETLOW is offline   Reply With Quote
Old 03-21-2011, 02:12 PM   #2
PLANETGETLOW
Re: Air Shocks & PSI ??
Anybody?
Old 03-21-2011, 02:25 PM   #3
PLANETGETLOW
Oh well, I found this out and thought I'd share it in case anybody else has similar questions:
Monroe Max-Air shocks are ideal for vehicles that occasionally tow trailers or haul loads. They are designed to maintain level vehicle height. Inflates and deflates from 20 psi to 150 psi., even while the vehicle is loaded.
http://www.shockwarehouse.com/site/mon_air.cfm
Old 03-21-2011, 07:07 PM   #4
broey
Square
broey's Avatar
About 10 years ago I ran monroe air shocks in my 88 civic, I used 6 ball valves, air plane grade air lines and a nitrogen tank pushing 400 p.s.i and I never once blew a line or a shock seal. it was awesome.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 03-21-2011, 07:34 PM   #5
LONGHAIR
I'm not a fan of air-shocks, simply because the shock mounts were never designed to carry that kind of load. The upper mounts (studs) are "single shear" which is weak to start with and these frames are known to have issues with this anyway.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-22-2011, 09:00 AM   #6
PLANETGETLOW
DAMN!!
Well, the air-shock is a band-aid option if you will right now. The truck will be getting bagged next year and this year we just did a static drop (flipped leafs and lowering blocks). The Air-shocks are being used JUST to even the lift. There will be NO load on them except the bed weight.
Old 03-22-2011, 09:49 AM   #7
cdowns
cdowns's Avatar
the main thing with air shocks is it is normal for them to bleed down some over time so you always need to keep an eye on the pressure as running them without air will damage them very quickly// dad had a few caprice station wagons that they came from the factory with them as part of the heavy duty trailer package in the 70's-80's vintage
Old 07-03-2011, 12:52 PM   #8
iceship
Planetgetlow.... how is the ride on the airshocks, I have a flip and shakles and I'm seating on the rear end..need to raise it 2in for better ride on bumps...
iceship is offline   Reply With Quote
Old 07-03-2011, 01:02 PM   #9
PLANETGETLOW
The ride is actually pretty damn good!
Old 07-03-2011, 01:27 PM   #10
SCOTI
SCOTI's Avatar
Do it right & take the shackles back off.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
