Old 03-21-2011, 02:50 PM   #1
FrankC
WTB: Vacuum Selector for A/C Control
Does anyone have a NOS, good used one available? My current switch is has two vacuum ports , but can convert to a 3 port system.
Tried to rebuild mine - holds a vacuum now - but will leak in between settings.
Thanks,
Frank
PS Will consider a control as well.
Thanks,
Frank
FrankC is offline   Reply With Quote
Old 03-21-2011, 03:22 PM   #2
bikerbuck
Re: WTB: Vacuum Selector for A/C Control
Not positive but i think one side is suppose to bleed off between settings.
bikerbuck is offline   Reply With Quote
Old 03-21-2011, 04:01 PM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I would love to see a vacum diagram I have to attack mine this summer
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-21-2011, 04:40 PM   #4
FrankC
bikerbuck - Hmmn - I wondered if that was by design.
Anyone else weigh in?
Frank
Thanks,
Frank
Old 03-21-2011, 04:42 PM   #5
FrankC
Hottrucks: You can check my thread in the message board. The community was kind enough to supply wiring and vacuum routing.
http://67-72chevytrucks.com/vboard/s...d.php?t=449832
Thanks,
Frank
Old 03-21-2011, 05:47 PM   #6
Hottrucks
Hottrucks's Avatar
SWEET got it in the saved pile...my truck will be in Fla next winter so I want it up and working this summer
THANX
Old 03-21-2011, 07:07 PM   #7
bikerbuck
Frank..Believe it was by design, If your leaking through the valve itself and are testing the side that goes to your actuators it will bleed off between settings. This wont ever be a problem because it wont get vacuum from the other side (Vacuum source) in that position. IF that makes any sense.
Old 03-22-2011, 09:05 AM   #8
FrankC
Hey - well I might be ok.
The air has not worked for so long I did not remember. Will try it again today.
Frank
Thanks,
Frank
