03-21-2011, 05:19 PM | #1 |
Who Me?
Hood Hinges
What is the deal with the hood hinges? When the back of the hood stick up is that from a worn hinge?
Is there a low buck fix with the old hinge?
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
03-21-2011, 07:08 PM | #2 |
1 thing at a time is progress.
Re: Hood Hinges
Crazy question, did you try adjusting the hinge? If so what's the position of the hinge at the front and rear bolt?
Alan
Philippians 2:14-16 |
03-21-2011, 08:12 PM | #3 |
Who Me?
Re: Hood Hinges
I dont think the front bolt hole is sloted and the rear is down as low as it will go.
03-21-2011, 09:09 PM | #4 |
Re: Hood Hinges
A friend of mine had that same problem, and it was caused by an inexpensive seal that held the back end up. I turned him on to a seal that folds over like a horizontal V, and that cured the problem. Can't remember where I got it!
03-21-2011, 10:20 PM | #5 |
Re: Hood Hinges
i have had the same problem with my 66 i have no seal so that shouldnt be the problem i switched hinges it got better but still sticks up . the hinges i switched out were used so i beleive it is a hinge issue hopefully someone can help us on this
03-21-2011, 11:08 PM | #6 |
Re: Hood Hinges
I didn't make it out to the shop tonight to do some looking. I haven't tried this idea, but I would try to elongate the rear hole to allow it to be adjusted down some more. If that works then maybe the hinge has some wear. This is a total guess right now. Maybe someone will have a better answer.
Alan
03-21-2011, 11:34 PM | #7 |
Re: Hood Hinges
I have the same problem. I don't think its an adjustment issue with mine. Each time I close it I have to go to the cowl and push it down. Its like it doesn't close all of the motion up on the hinge. I haven't made an honest attempt to fix it. I wonder if the spring could be an issue?
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
03-21-2011, 11:56 PM | #8 | |
Re: Hood Hinges
rbar might be right as well.
Alan
03-22-2011, 01:43 AM | #9 |
Re: Hood Hinges
before he got the '66 we have now, my son had a '64. one day the hood popped up while he was driving it & after that the hood would never shut right, always high at the back. it fit perfect before & we never could get it back the way it was. sprung?
andy |
03-22-2011, 07:16 AM | #10 | |
Who Me?
Re: Hood Hinges
Also, has anyone bought hinges from LMC? If so, did they work better? I saw they were around $45 each.
03-22-2011, 11:09 PM | #11 |
Resistance is Futile
Re: Hood Hinges
I have read on the board that it means the hinges are shot, but I have no idea if this is true or not. After reinstalling my 'burb hood I have it slightly out of wack and it doesnt close like before. Could be the hinges fight each other?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-22-2011, 11:23 PM | #12 |
Re: Hood Hinges
I might also remove the hood stricker to eliminate any bind. That way your sure it is only a hinge problem.
Alan
03-23-2011, 12:32 AM | #13 |
60-66 Nut
Re: Hood Hinges
I have fixed a similar situation by just adjusting the hinges. I don't remember the exact procedure, but it took some trial and error to get it right. Sometimes lubrication all the pivot points will also help.
03-23-2011, 09:20 AM | #14 | |
Re: Hood Hinges
I have the identical situation, but the hood sticks up only on the diver's side in the rear. I close the hood, push the rear down, get in and drive. I'll take a look at it eventually, but there's a lot more pressing things that need to be addressed first. |
03-23-2011, 09:37 AM | #15 |
Who Me?
Re: Hood Hinges
Mine seems to be more on the drivers side too.
03-23-2011, 07:07 PM | #16 |
Senior Enthusiast
Re: Hood Hinges
03-23-2011, 07:30 PM | #17 |
Who Me?
Re: Hood Hinges
Thanks for that info!
03-23-2011, 09:33 PM | #18 |
Re: Hood Hinges
Awesome Mark!!! Who's gotten it done yet??
03-24-2011, 07:25 AM | #19 |
Who Me?
Re: Hood Hinges
Not me so far, maybe this weekend
03-24-2011, 07:40 AM | #20 |
UCA63
Re: Hood Hinges
Great info Mark,thank you
T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
