Need a good photo to work from
I am looking to have my daughter make me a nice "inspiration" photoshop work, of what my truck will look like when finished. To that end, I need a good photo for her to work from.
I have the picture below, which is perfect in every way except one... it is too small. I grabbed this photo from off the web, and don't know where it came from, so I have no recourse to getting a higher-resolution copy of it. Can anyone help me with a higher resolution photo we can use? Even if it's not the right color, I believe she can change the coloring. My truck is a 72, and will be mostly stock, medium-olive when I get done.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Re: Need a good photo to work from
I can e-mail you a high resolution photo like this one. Just PM your e-mail address to me.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
go to Cardomain.com and look at the trucks there you should be able to find a truck on there most are in high res and large pics just click on the right click on the pics select open in a new window (or tab) and you will see the pic in it's full size and res
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff |
Jim, PM sent. That's a fine looking truck you have there, many thanks.
71, I'll head over there and check that out. I spent some time going through the 67-72 gallery here as well.
