Old 03-22-2011, 04:42 PM   #1
oldtrux
oldtrux's Avatar
pinion angle question
hello all,i am installing a 4/6 drop on my 66 and was wondering if someone might know what degree shims i would need for the rear end to correct the driveline angle?also can you purchase these or do you have to fab them?thanks for any help!
oldtrux is offline   Reply With Quote
Old 03-22-2011, 04:58 PM   #2
1966JSM
Re: pinion angle question
I believe you need 3 to 5 degree shim
1966JSM is offline   Reply With Quote
Old 03-22-2011, 05:24 PM   #3
oldtrux
oldtrux's Avatar
thanks jsm,do you know if you can purchase these?i havn't seen them??
Old 03-22-2011, 06:49 PM   #4
SCOTI
SCOTI's Avatar
Try it before buying shims. Truck arm or leafs suspension?
I've done multiple truck-arm trucks w/more than 6" rear drops & did not adjust the pinion angle. None had issues. This is one of those items where it's easy enough to do after if necessary vs. spending time/money up front when it's possibly not required.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-22-2011, 07:03 PM   #5
1966JSM
summit racing has them for 16 bucks plus shipping. my truck needed them due to the drop and engine and trans setup I have.
I would do it its cheap insurance
Old 03-22-2011, 07:52 PM   #6
oldtrux
oldtrux's Avatar
it has coil springs,i hear you,makes sense to wait and see if i need them and summit has them.thanks guys i appreciate your help!
Old 03-23-2011, 06:27 AM   #7
PGSigns
PGSigns's Avatar
I bagged the back of mine for a bout the same drop as you are doing or just a little more and the pinion angle was fine.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-23-2011, 06:44 PM   #8
SCOTI
SCOTI's Avatar
Summit Racing has pinion shims for truck arm suspensions?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-24-2011, 01:23 PM   #9
1970C10truck
1970C10truck's Avatar
I couldnt find anything on the summit site the other day. I did find some interesting things at speedwaymotors.com that I couldnt find anywhere else.
1970 C10 swb 350 4spd under construction
1970C10truck is offline   Reply With Quote
Old 03-25-2011, 02:17 AM   #10
scum1
scum1's Avatar
what is the rule of thumb for this..i was looking at mine which i recently jsut lowered about 6 inches id say..the angle looks a lil steep and i was thinking the same thing..a buddy of mine dropped his 62 pretty low and said he had some binding due to a steep angle. mine sounds fine driving but i dont want to have anything serious happen...im very new to all of this as it is.
scum1 is offline   Reply With Quote
Old 04-01-2011, 01:30 AM   #11
Rooster's 67
Rooster's 67's Avatar
the angle between the output of trans to driveshaft for a street driven truck should be between 1-3 deg and like wise 1-3 deg at the driveshaft to pinion thereby canceling each other out.
in other words if the output shaft of the trans is neg (angled down) 3 deg then the pinion should be set at 3 deg positive (or angled up) they should be operating in parallel planes.
likewise the angle of the driveshaft to pinion and output shaft should not exceed 3deg or faster wear is very possible.
all theseare for a street driven vehicle and should be set at ride height.
check out this info from Streetrodder mag, the pictures give a good description
http://www.streetrodderweb.com/tech/...les/index.html
Last edited by Rooster's 67; 04-01-2011 at 01:44 AM. Reason: mag link for better explanation
Rooster's 67 is offline   Reply With Quote
Old 04-01-2011, 11:50 AM   #12
oldtrux
oldtrux's Avatar
great info roosters 67.thanks very much!
Old 04-01-2011, 12:09 PM   #13
Rooster's 67
oldtrux,
hey no problem,
I just like to spread good correct and precise info so everyone can learn and make good wise choises.
But like Scoti said, you may not have any noticeable issues with just lowering if you have truck arms, you may still have "bad angles" with what might be accelerated wear though.
