03-22-2011, 06:49 PM | #1 |
Anyone use a S10 Bed floor in the 55-59 shortbed trucks?
Hello,
after going though some searches I found a few people using S10 bed floors in AD and TF trucks, anyone have some pics of the install? im not a big fan of the wood beds... looking for a cheap alternative, the mini tubs would be helpfull too... my original thought was just a piece of diamond plate... guess I could always go back to that route... Other 'Steel' options to replace wood floor? |
03-22-2011, 09:04 PM | #2 |
Re: Anyone use a S10 Bed floor in the 55-59 shortbed trucks?
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
03-22-2011, 10:01 PM | #3 |
i have seen a 53 with an s-10 bed on it but with the factory rear fenders mounted on it and looked pretty good if your going in that direction. the only problem i could see with replacing just the floor is if the s-10 floor is going to wide enough for your bed but a little metal and welder can go along way.
03-23-2011, 09:38 PM | #4 |
I'm in the process of cutting up a steel floor to install. I found that the S10 and Ranger floors aren't a good length for my short box 56. BUT the 90's model Dakotas are the PERFECT length. I measured the Dakota floor at 1" longer than I need, and I'm trimming a few inches off the sides but retaining the factory wheel wells which will give me a 2" mini tub. Got my Dakota bed for $50.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
03-23-2011, 09:51 PM | #5 |
pics of the floor as trimmed to drop in...still working out the mounting details as the 3rd rail back conflicts with my under bed gas tank.
03-23-2011, 09:54 PM | #6 |
And what I hope it will look like very soon...
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 Last edited by OKGMC4; 03-23-2011 at 09:54 PM. |
03-24-2011, 11:28 PM | #7 |
Oh that's freaking cool, thanks for the info. I love new ideas that i can use...
03-24-2011, 11:59 PM | #8 |
Thanks, this is pretty much just what i was looking for...
do you have a photo of the stock S10 mounting rails? I was hoping to use the factory '55 rails to support the bed... but i guess to do that I would have to cut off the factory S10 rails... my tank under my bed is from a mustang and sits on the bottom lip of the frame rails, so the S10 stock mounting rails would probably work.... do you have a photo of the bottom side of the bed? thanks again for the pics, your truck looks to be very far along from the backround photo! |
03-25-2011, 03:21 PM | #9 | |
I imagine the wheel bases didn't change much from the mid-80's model and the mid-90's model, I am guessing people use the 80's model? just for easier access to junked trucks... Going to the local junkyard this weekend to see if i can scout out a floor... i think they will sell a whole bed for around $200 beats buying a whole truck. i have enough cars on my property |
03-25-2011, 04:17 PM | #10 |
I am getting ready to put a 1995 s10 long bed floor in a 53 short bed. I already cut it out but I can take some pics of the bottom of it for you when I get a chance this weekend. How wide is the 55-59 bed?
My S-10 swap thread: http://www.killbillet.com/showthread.php?t=16296 |
03-25-2011, 08:45 PM | #11 |
Here ya go... the bottom of a 95 S10 long bed.
03-25-2011, 10:44 PM | #12 |
Mine is out of an 89-96 Dakota. The yard I went to had a ton of S10 and Ranger short beds but no long beds, and the short version is too short. The Dakota bed is 78 3/8 long and I need 77 3/8, I just cut the extra inch off the front end. That put the center of the wheel well around 37", exactly where it needs to be on a TF truck. The measurements for the TF I came up with are 77 3/8 long by 50 1/8 wide. The Dakota looks just like the S10 from the bottom. I may still end up using the stock rails as mounts but I 'll have to modify them to accept bolts from the bottom so all fasteners are hidden. It's just that the Dakota is a bigger truck and actually closer in size to a TF. I suspect the AD truck beds are smaller.
