![]() Join Date: Aug 2009
Side trim
How do you remove it without damaging it or the paint, the kind that it not bolted on. Thank's for any help
Posted via Mobile Device |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: Side trim
Sending you to the top so we both learn how
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
Re: Side trim
Nobody has removed their trim?
Member
Re: Side trim
Is it put on with the double sided tape? If so, try slightly pulling it away from body panels, then using a thin plastic or nylon scraper gently push it behind the tape. A clean bondo knife sometimes works, you can also spray a little WD-40 on the blade to help. Go slow and easy..., hope this helps
Re: Side trim
Thank's custom, but mine has the tapered push in clips that expand & hold on the back of the body pannel. I thought there is a special tool that would compress it to pull it out.
Re: Side trim
Mine had both kinds if it's a clip you almost have 2 get to the back side with a pliers and squeeze it to release them or take the nut off. I also found that pulling straight up then out and then pushing back down unhooked many of mine. but your gonna have 2 release a few of them. Just don't go back with the stick on kind they stick out 2 far and un-stick n about a month
Re: Side trim
Thank's short step, I'll give that a try.
Re: Side trim
Dad always said I was a lot better @ tearing stuff apart then I was @ putting it back together lol
