Old 03-23-2011, 12:51 AM   #1
funkytechmonkey
funkytechmonkey's Avatar
any pics of drop members with factory spindles?
Curious if anyone around here has done a 67-72 dropmember but kept the factory spindles?
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 03-23-2011, 09:59 AM   #2
kieth
kieth's Avatar
Re: any pics of drop members with factory spindles?
You can get some lowering by cutting off the front coils, but you give up suspension travel. The reason everyone goes to drop spindles is you can still maintain the suspension travel while dropping 2-2.5" In order to go lower than that you have to add new control arms which are designed with the proper geometry to allow air bags up front and even more drop. This may even require changes in the type of steering to get the drop even more extreme. Kieth Spend a little time searching here you can find out a lot of info, but if you are mechanicly challenged you might want to go to the pros to accomplish your design.
kieth is offline   Reply With Quote
Old 03-23-2011, 10:10 AM   #3
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
The arms are cupped from when I had them on my old Zed and chopped suspension. I have another set of stock arms that will replace these. They are 73-87 arms.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 03-23-2011, 02:04 PM   #4
funkytechmonkey
Mike, how far from the ground does it sit? Do you have a pic of that?
Im not looking to go lower. The reason I'm asking is... I am only doing a mild notch on the back and I have no desire to "lay frame" so I want a good stance in the front to match the back. I am installing
The porterbuilt drop member with bags and I don't want it to sit too low. So I was thinking about using the stock spindles instead of the drop spindles.
Anyone else running a similar setup?
Old 03-23-2011, 02:06 PM   #5
hotrodhomi
hotrodhomi's Avatar
Are your bags rubbing the LCA?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 03-23-2011, 02:29 PM   #6
BACKYARD88
BACKYARD88's Avatar
I don't remember what size tire that is on the front but it's a 17" wheel. With no bags on the front it lays frame. I don't have the un-cut arms on yet so I can't say for sure but I would say around 2" between the framerails and the ground aired out. If you are using stock lower arms you can trim the lower cups to tune your ride height and get it where you want it.
Yes, the DM moves the bags out further than the springs would normally sit. That's why I am replacing the arms.
-Mike Owen-
Old 03-23-2011, 03:11 PM   #7
chapster
chapster's Avatar
Hey Funkytechmonkey,
Is your plan to run with or without inner fenders? Another option is stock front cross member with porterbuilt A-arms and drop spindles.
I believe there is a pic of Accuair install set up like this.
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline   Reply With Quote
Old 03-23-2011, 05:12 PM   #8
jimmydean
jimmydean's Avatar
After talking to Nate, I will be using the stock 73+ arms and spindles. Should be about an inch off the ground with a 28" tire.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-23-2011, 10:40 PM   #9
texastrendz
i actually set mine up with drop spindles but had to go back to stock spindles because i was not getting enough lift with the tire size. it is all relative to the height of the tire. i am running a 255 50 17 and it was way low in the front with a dropped spindle. i installed the stockers and it is now perfect. it just barely kisses the ground right now with no motor. when the motor gets installed it should push it just to the pavement. when you get into the 20" plus size wheels when the drop spindles come into play.
texastrendz is offline   Reply With Quote
Old 03-23-2011, 10:49 PM   #10
texastrendz
dont know if this helps. this is with factory 73-87 arms, stock spindles, and porterbuilt dropmember. i am also using a bag plate instead of a cup that i got from porterbuilt.
Old 03-23-2011, 11:00 PM   #11
funkytechmonkey
I will eventually like to get inner fenders.
I plan on running 20" front and rear. My front suspension is going to be the porterbuilt dropmember, and porterbuilt upper and lower control arms. The biggest concern of mine is how level the truck will be aired out.
Old 03-23-2011, 11:06 PM   #12
bguild
bguild's Avatar
Are you going to sell me your drop spindles cheap ?? (-:
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 03-23-2011, 11:28 PM   #13
texastrendz
nope, this will not be my only dropmember build. i am planning a 66 with some really big wheels.
