Old 03-23-2011, 03:30 AM   #1
1986swb
1986swb's Avatar
10-bolt rear end swap
Has anyone successfully changed out a 10-bolt rear end from an early-1990s suburban to a mid-80s full-sized chevy/gmc?
Is there a repository for rear end specs and dimensions available on 1980s and 1990s trucks and suvs?
I need to know if the 10-bolt rear end from a 1990 suburban will be a direct fit/replacement in my 1986 GMC C1500 truck.
Specs I found on 10-bolt rears:
1986 (8.5", 1.28 axle diameter, 28 spline)
1990 (8.5", 1.28 axle diameter, 30 spline)
Let me know your thoughts.
1986 GMC Sierra Classic C1500 SWB
2006 GMC Yukon Denali
http://67-72chevytrucks.com/vboard/a...hp?albumid=977
1986swb is offline   Reply With Quote
Old 03-23-2011, 03:48 AM   #2
Altec
Getcha Pull
Altec's Avatar
Re: 10-bolt rear end swap
Should bolt right in. Any suburban between '89-91. The only possible issue is spring pad location. Which shouldn't be. Not until '92.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-23-2011, 08:11 AM   #3
silvereagle07
silvereagle07's Avatar
They are a direct fit. I swapped one into my 84 from my 91 burb donor truck. The only difference I had was changing the yoke on the driveshaft to fit because I had a 12 bolt in previously.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-23-2011, 11:31 AM   #4
1986swb
1986swb's Avatar
Thanks Altec and Silvereagle for your insights.
Now does $250 sound like a good deal? It is a posi unit and comes complete with uncut e-brake cable. I think it is but seeing is believing, right?
Old 03-23-2011, 12:16 PM   #5
1986swb
1986swb's Avatar
Couple of additional questions:
1. Will my 15"x8" steel ralley wheels fit on the 5-lug bolt pattern on the 1990 10-bolt rear end?
2. If the ralleys will fit, can I use the same lug nuts or do I need differnt lug nuts?
Old 03-23-2011, 01:42 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
The sub axel is identical to our trucks. Yes your ralley will fit on it. Yes you can use the same lugs. Now be sure it's not a 6 bolt axel!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-23-2011, 01:51 PM   #7
thesickc10
i dont mean to jack your thread but i have a line on a posi 6 lug 10 bolt out of a 80's truck and was wondering if i can pull the 6 lug axles out and put the 5 lug axles in
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 03-23-2011, 08:38 PM   #8
1986swb
1986swb's Avatar
Just picked up the limited slip differential. All is in tact with stock 3.08 gears similar to my truck. Pics to follow.
Old 03-23-2011, 10:51 PM   #9
1986swb
1986swb's Avatar
As promised, here are some pics. I'm hoping this "new" limited slip 10-bolt differential will improve my traction off the line and during wet weather conditions. And yes it is a 5-bolt lug pattern.
I also recently picked up a mid-70s, C10, 8-foot trailer for a spring time project. I plan to install my current 1986 GMC SWB rear end into the trailer to replace the existing 14-bolt, 8-lug behemoth. The trailer will then be fitted with 15"x8" ralley wheels. Once the limited slip is cleaned up, it will be installed in my 1986 GMC.
Old 03-23-2011, 11:21 PM   #10
83burban
As long as the splines are the same they will swap fine. If not then you might want to have them re-drilled or get new shafts made
83burban is offline   Reply With Quote
Old 03-23-2011, 11:29 PM   #11
1986swb
1986swb's Avatar
Not sure why I need to worry about the splines as the entire rear end is being swapped out. The "new" rear end should bolt in directly where the original is, shock mountings, leaf springs, etc. should be a direct fit.
Am I missing something that I need to be concerned about?
Old 03-24-2011, 09:51 AM   #12
silvereagle07
I think he was referring to this ^^^^. Glad to see you got the rear axle 1986swb. That's a cool looking trailer too.
Jeramy
'85 Chevy 4X4 SOLD
Old 03-24-2011, 07:30 PM   #13
1986swb
1986swb's Avatar
My bad. I'll read the threads a little more before replying.
