Not too old to learn
Bed slats that hold up the wood.
One of the problems I have in waiting so long to rebuild my truck,
is forget where what goes where. I did bag and mark all the bolts and screws, and put tape on the wiring looms otherwise my feeble brain would shut down. I know none of you have ever had this problem............. ![]() Anyway to the bed question : It is a long Fleetside wood bed and there are several channel cross slats ( see don't even know what to call those ) that all look the same, but one. It is about half as tall as the others. Where dose it go ????????
1968 C10 a way to long restoration. |
Junior Member
Re: Bed slats that hold up the wood.
GMC Paul's and LMC web-sites have pretty good views of where the cross pieces go. I can not remember for sure myself, but some day will have to when I put the short step bed on the '67.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Went to his site earlier, very good info on wood dimensions
and bolt locations, but couldn't find a section for the slat locations ? Will try LMC. Thanks.
1968 C10 a way to long restoration. Last edited by 8door; 03-23-2011 at 08:04 PM. |
![]() Join Date: Oct 2009
I'm sure that one goes in the middle (above the rear end housing).
Posted via Mobile Device |
Bingo, both you guys.
That's were I bought my wood. The thin one is also where the muffler heat shields will go.
