aka Crusher, Crushergmc
What size is the 12 point on the rag joint?
I need to get the old steering rag joint off so I need to buy a socket. What size is it? Thanks
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
Recovering Truck Driver
I just went out to look at mine, but they are both so covered in grease that I can't see them. Most likely it takes a 7/16. maybe a 1/2.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
It is a 7/16" 12 point.
Jim |
Thanks guys, I'll go out and buy one.
Gotta Startem Early
The cool thing about 12pt bolts is that the socket size is the same as the bolt size, example, if you have a half inch bolt then it takes a half inch socket.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
