Old 03-23-2011, 09:33 PM   #1
Patsfan34
Patsfan34's Avatar
Suggestions on body mount/cab mount kit?
I'm almost at the point of mounting the body and getting this truck to paint before final assembly. Any and all suggestions welcome. Should I go rubber, should I go poly? Why, which manufacturer? My frame is a 68 GMC 4x4 1/2 ton SWB.
Thanks in advance!
Neil
Patsfan34 is offline   Reply With Quote
Old 03-24-2011, 10:00 AM   #2
Burt4x4
Burt4x4's Avatar
Re: Suggestions on body mount/cab mount kit?
Over 12yrs ago I went Energy Suspension Black Poly Body/tranny/xfercase mounts. My rubber mounts were toast.
The trick with Poly is not too over tighten or squeese it. Then use a nylon lock nut too keep the mount secure.
I have had zero issues eversence
Oh and I was told Black has polygraphite impregnated within to prevent "poly squeek" Red does not have this feature.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
