What battery do you prefer post or side terminal?
My truck has side terminals. The dude at autozone says they suck and that I should get a battery with posts. What do you guys think? Is it worth it to switch over to posts?
NOT REALLY BANNED!
![]() Join Date: Jul 2004
Re: What battery do you prefer post or side terminal?
I like the side terminal batteries. Much easier to unhook the connections without damaging anything.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
I prefer top post, but I also always run terminal ends with removable leads.
Side Terminals are the best design out there. they won't corrode if the cable isn't damaged. Top posts are OLD tech and require maintenance. For once GM built the better mouse trap.
The only thing I can think of that top posts are better for is hooking up lots of accessories, and only then because dang near everyone ONLY makes adapters for top posts. |
![]() Join Date: Apr 2004
Dual post batteries are great. I like the side post hook up with the top posts free for jumps/ stereos.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
I bought a replacement connector for my side connector battery in my car that had a threaded end on the back side, so I could bolt on any accessory I wanted... worked great! Never had a problem. This truck? 3 months, had tons of problems with the top posts. Stranded on the side of the road multiple times, burned through like 5 connectors.
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic. |
#8 | |
![]() Join Date: Jul 2010
Side posts are a much cleaner looking instal..
the dude works at autozone because he doesn't know whats hes talking about.
Each one has its uses - i prefer side batteries with both. Side for normal connections and post for accessories like winch etc. |
I prefer top post but have side currently.
I had the connector that was on there corrode, and fall apart while driving. Then I had a few instances where the battery slid on the homemade battery tray forward, so the hot hit the front of the truck, and shorted out. A longer ground, so I can flip the battery around will pretty much fix my problem...
#13 |
Getcha Pull
Bingo!
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
#14 |
78 Big10 454
![]() Join Date: Jul 2008
My square has factory dual batteries. My primary is side post and my secondary is top post.
#15 |
![]() Join Date: Mar 2008
Purchase a battery with both posts. Reason. For stereo/amp system setups (require lots of grounding and direct power source) and then some. The side posts are good for jumper cables and for your trickle battery charger hookups. See pic.
1986 GMC Sierra Classic C1500 SWB 2006 GMC Yukon Denali http://67-72chevytrucks.com/vboard/a...hp?albumid=977 |
#16 |
I will never buy another side post battery again, i have seen to many die by the side connectors literally melting off on high draw applications(such as a 200-300 amp draw10,000lbs+ winch, or a boost on a semi rig)
I have never seen a top post melt off, ever, even when welding with a pair of jumper cables with 4 or 5 batteries hooked up to them which must be 200 amps+. First thing i did when i bought the truck is buy a new top post battery. |
#17 | ||
78K & 79C Jimmys
you will get better power to the other truck from the extra top post
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#18 |
![]() Join Date: Dec 2010
Both have their pros & cons, but I prefer the top post style personally - mine had duals from the factory & will have when it's done - both Optima Red Top's with top posts. Yes they require a little more care & maintenance, but come on people - we are all talking about square body Chevy's here - which are older vehicles & generally require more maintenance anyhow so you're probably gonna be under the hood fairly regularly - either showing it off, cleaning it or even just checking everything out. If you were really worried about that kind of thing you should probably just get a new truck so you really never have to open the hood....
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
#19 |
I agree. I use batteries with both posts in my trucks. I like the ability to add things to power source without a lot of clutter. 1986swb that's a clean install, I like the kicker terminal ends.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT Last edited by silvereagle07; 03-24-2011 at 09:30 AM. |
#20 |
Moderator
![]() Join Date: Oct 2008
If your side post lugs are in good shape keep em. I run dual post batteries with side post cables. Makes jumpstarting another rig easy.
#21 |
What's so good about dual post batteries?
1986 Single cab 2WD Chevy 350/350 ![]() 1977 Single cab Dually C30 BB454!
#22 |
I use dual terminal batteries because it makes jump starting other vehicles or machinery a helluva lot easier. Without the top posts you've got to make sure you have a good connection to the wimpy little side terminals.
Andrew 1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10 1988 C1500 Scottsdale 305, 700R4, 3.08 1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10 |
#23 |
I prefer top posts i think that it is a better connection plus i have seen side connections striped out and the battery not being able to be use anymore
#24 |
Top post all the way. No reason to go with side post, thats just asking for a hard time.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
#25 |
Both posts and you'll never go back to single posts
Its Kool to be a square ![]() 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers New Mexico Member --- Member of the Square Body Club ---
| Bookmarks |
