Closed Thread
Old 03-24-2011, 07:05 AM   #1
busarich
My 1958 Apache build
I picked up a 58 apache short bed step side with a 74 C20 frame underneath it. Ordered a CA Chassis Works back half kit with autoweld 4 link kit, QA1's, Centerline 15X15 rims, mickey thompson 29X18's and have all of the patch panels in. I will post pics up later of the progress. I am going to go to the junk yard this weekend and try to locate a camaro front clip.
Stuff to still order and do
Front rims and tires
front and rear fenders
roll cage
lexan windows
chop the top
bed sides
roll pan
front bumper/brackets
and all the stuff for a 496 stroker build. This stuff is gonig to add up fast
it has a 12 bolt in it now so I have to chop the housing and new axles.
First project to this level. The best part about this project is all of the tools that I have got. Drill press, pipe bender, welder, plasma cutter, blast cabinet, air compressor, sheet metal brake, powder coat set up, soda blaster, and am getting the stuff to build my powder coat oven this weekend. 39"X39"X66". I will keep updating this post with progress.
busarich is offline
Old 03-25-2011, 01:28 AM   #2
RockTonka
RockTonka's Avatar
Re: My 1958 Apache build
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline
Old 03-25-2011, 01:55 AM   #3
busarich
I know. All the pics are on my phone and it won't let me post them from my phone.
R
busarich is offline
Old 03-25-2011, 02:40 AM   #4
busarich
Lets try this. Here is when I first got it and started pulling it apart. Just got the hood off.
busarich is offline
Old 03-25-2011, 02:42 AM   #5
busarich
Here are pics of the front cab corners
busarich is offline
Old 03-25-2011, 02:47 AM   #6
busarich
Here are some of the rear cab corners.
busarich is offline
Old 03-25-2011, 02:48 AM   #7
busarich
Here are some of the back of the cab.
busarich is offline
Old 03-25-2011, 02:50 AM   #8
busarich
Here are some of the new tires. 29X18 mickey thompsons
busarich is offline
Old 03-25-2011, 02:51 AM   #9
busarich
Here are some of the front end tore down.
busarich is offline
Old 03-25-2011, 02:52 PM   #10
Number 9
Looking good. Keep posting.
Number 9 is offline
Old 03-25-2011, 08:40 PM   #11
busarich
Got almost all of the patch panels in today. About to get started this weekend.
busarich is offline
Old 03-25-2011, 08:42 PM   #12
busarich
Here are the outer rear cab corners, and outer lower door skins.
busarich is offline
Old 03-25-2011, 08:43 PM   #13
busarich
Here are the lower inner front door hinge pillars, inner lower door skins, and the inner cowl kick plates.
busarich is offline
Old 03-25-2011, 08:44 PM   #14
busarich
Here are the last of them. Inner cab corners, front door pillar lower cab pillars, and the Door sill w/ rocker panels.
busarich is offline
Old 03-25-2011, 08:47 PM   #15
busarich
Still gotta get the 2 front fenders, 2 rear fenders (3" wider), running boards (3" wider), upper outer cowl panels. That should be all for the body panels, then I am going to make my own fire wall, and floor. I should get my bead roller in on monday.
busarich is offline
Old 03-25-2011, 09:20 PM   #16
entourageguy
Yellow truck club
entourageguy's Avatar
Wow when we said we needed pictures you came thru big time. Good luck on the build. We need more 4 lighter on here.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline
Old 03-26-2011, 12:13 AM   #17
OrrieG
OrrieG's Avatar
Lots of work ahead, make sure you brace your cab real good or door fitment will be a pain.
OrrieG is offline
Old 03-26-2011, 12:53 AM   #18
busarich
You talking about when I chop it? I have been reading a ton on the board about it and that is one thing I def. Took note on. Thanks for looking out.
busarich is offline
Old 03-27-2011, 12:43 AM   #19
busarich
Made some more progress, got the front and rear glass out. Here is a pic, got the interior stripped and ready to pull the cab off.
busarich is offline
Old 03-27-2011, 12:46 AM   #20
busarich
Got the bed floor stripped and ready to be pulled. For some reason the guy that I got it from welded the bed floor mounts to the frame. So I got a chance to use my plasma cutter. GOOD TIMES. Here are some pics of me and my buddy Biff getting the bed ready to pull off.
busarich is offline
Old 03-27-2011, 12:48 AM   #21
busarich
Here are some pics of us cutting the cross sills. The bed and the cab are ready to pull of now. I will get that pulled sometime this week. Instead of going with the camaro front clip I am going to go with the S10 frame swap. I can get the frame for 100-200$.
busarich is offline
Old 03-27-2011, 03:22 AM   #22
dicer
Isn't it a fun job removing the nice rusty bolts in the beds? NOT
dicer is offline
Old 03-27-2011, 10:30 AM   #23
busarich
Yeah all of them on both rear fenders broke off but two of them.
busarich is offline
Old 04-01-2011, 02:02 PM   #24
busarich
Look what came in today. Auto weld 4 link setup with upgraded QA1 coil overs.
busarich is offline
Old 04-01-2011, 02:22 PM   #25
Kim57
Kim57's Avatar
Cool stuff. I always like getting things for the truck.
Kim
Kim57 is offline
Closed Thread
