Old 03-24-2011, 12:43 PM   #1
Hertzdaddy
Control arm fixes needed
So I finally got around to making some changes on the front of my 73 Jimmy and found some issues. It appears that the leading edge of the control arms where they mount to the cross shaft struck some solid object at some point in the past and was severely bent.
It also appears that the impact moved the cross shaft back in the frame mounts and may have locked up the control arm altogether. The mounts show signs of rotation wear and the locating pins have worn to the point where I'm not sure they even extend into cross shaft any more.
So I need to fix it. I'm thinking I will go with tubular lca's. As for the mounts, I don't really have a good plan yet. Does any one make a replacement? Has anybody else faced this problem and fixed it successfully. Looking for input. TIA
BTW, 2.5" lowering spindles and 2.5" springs with a healthy additional cut does not make for a streetable combination. Inflicted by a PO, not me.
Eric
Hertzdaddy is offline   Reply With Quote
Old 03-25-2011, 07:49 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Control arm fixes needed
I would just replace the a-arm.
CPP sells quality tubular a-arms for coil springs.
I don't know if anyone makes a replacement cross shaft saddle.
Keith
Convert to disc brakes.
Old 03-27-2011, 08:12 PM   #3
Gemp
Gemp's Avatar
Eric, Your pics are not giving me a warm ans fuzzy feeling.....Both of my arms took an hit like that. I have yet to have it apart.
06' GMC 1500 Crew cab.....
Gemp is offline   Reply With Quote
Old 03-29-2011, 09:54 AM   #4
Hertzdaddy
FYI on the shaft saddles:
http://www.classicparts.com/Chassis/products/387/3/0
Old 03-30-2011, 04:17 PM   #5
Gemp
Gemp's Avatar
Thanks for the link.....I think I'm going to need it.
