Old 03-24-2011, 03:33 PM   #1
redhead69
fugedaboutit
redhead69's Avatar
Misc parts for sale
Please respond to thread. All prices are plus shipping and the bigger items will kill the deal so come pick them up in Portland.
Inline 6 oil pan, pickup tube, engine towers/mounts 35.00
Brake booster (unkown condition) with brackets I think it was off a 1971 4x4? 20.00
Headlight buckets painted off my 69 driver quality 10.00
3.07 Ring and pinion out of my 69 12 bolt, good shape just went to a 3.73 35.00
Misc brackets.. a few alternator upppers Drivers side I think, and sb radiator upper supports, also a few clutch pcs 15.00
Green auto non tilt steering column w/ steering wheel. Sold 40.00 The steering wheel is pretty beat up, scratches from being moved around upside down like in pics but the column was tight and complete iirc.. out of a 69 th400 truck
Blue steering wheel of a 68 (i think) pretty nice but some minor cracks and paint rub.. nice horn cap 30.00 SOLD
More to come.. thanks
eric
Currently truckless
redhead69 is offline   Reply With Quote
Old 03-24-2011, 03:37 PM   #2
Fesser
Fesser's Avatar
Re: Misc parts for sale
I'll take the column. Shipping will be to 94559. You can keep the wheel. What six cylinder did the engine towers go to? Frank
Fesser is offline   Reply With Quote
Old 03-24-2011, 03:49 PM   #3
redhead69
fugedaboutit
redhead69's Avatar
Crown Vic police fan.. supposed to outflow the Taurus fans but wouldnt fit with my big block radiator and forward v8 combo without mods.. 30.00 sold
Holley parts/ rebuilder carbs. 770 holley truck 35.00sold, 650 dp main body 15.00, I think the other vac secondary is 650 20.00,and I can get numbers if anyone is interested
Stock th400 pan 10.00 and lokar th400 kickdown 25.00 Lokar needs the spacer washers but worked fine.. went to an aftermarket pan and wouldnt work.. could be remote mounted anywhere as is
Wiper motor.. worked when removed from a 69 15.00 and backup light gaskets 2.00 new
Gas pedal ok condition 10.00 and 2.25" ball flange header reducers 10.00
Currently truckless
Old 03-24-2011, 03:53 PM   #4
redhead69
fugedaboutit
redhead69's Avatar
Frank your in cali so lets just call it 55.00 shipped and if its less than 20.00 to ship I'll refund some money.. sound ok?
Not sure on the engine towers but was told it would work for my 250 i was gonna swap.. bought from a member here and can find out..
Edit: I was wrong.. bought the pan from a member and just pulled the towers from a yard.. to be honest I dont know, maybe someone can chime in and help?
Currently truckless
Old 03-24-2011, 03:54 PM   #5
coops714x4
coops714x4's Avatar
what carb has the elec choke if its the 770 ill take it
coops714x4 is offline   Reply With Quote
Old 03-24-2011, 04:02 PM   #6
redhead69
fugedaboutit
redhead69's Avatar
Coops the 770 has electric choke.. needs completely gone thru.. should go medium flat rate so 40.00 shipped is fine..
Currently truckless
Old 03-24-2011, 04:11 PM   #7
8door
Not too old to learn
If for any reason you part out the steering column, I am interested in the shift pointer an fiber optic cable. If it is the same as 67-68 looks like it might be.
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 03-24-2011, 04:16 PM   #8
coops714x4
coops714x4's Avatar
pm me with how you want to be paid for the carb can you give me the numbers on it thanks
Old 03-24-2011, 04:17 PM   #9
Fesser
Fesser's Avatar
Sounds good to me (on the column). How do you want to be paid?
Old 03-24-2011, 04:19 PM   #10
redhead69
fugedaboutit
redhead69's Avatar
I can do paypal or snail mail money order/ check.. pms being sent
Currently truckless
Old 03-24-2011, 04:58 PM   #11
Fesser
Fesser's Avatar
Might as well give me shipping on the fan too. If it isn't too bad I'll take it also. Frank
Old 03-24-2011, 05:08 PM   #12
redhead69
fugedaboutit
redhead69's Avatar
Frank I'll box it up the fan and take it down and see what they say..
Currently truckless
Old 03-24-2011, 06:56 PM   #13
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I'll take the blue 68 steering wheel. Horn button comes with correct? Let me know total shipped to 39531.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 03-24-2011, 07:00 PM   #14
redhead69
fugedaboutit
redhead69's Avatar
45.00 shipped to ya usmccevy, and yes button included
Currently truckless
Old 03-24-2011, 07:16 PM   #15
usmcchevy
usmcchevy's Avatar
Sounds good. Paypal addy please.
Build thread
LSx Swap FAQ index
Old 03-24-2011, 08:27 PM   #16
redbaron69
redbaron69's Avatar
would like to see some pics of the wheel, that was on the column you sold to fesser.
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 03-24-2011, 08:32 PM   #17
redhead69
fugedaboutit
redhead69's Avatar
The scuffing is continuous all the way around
Currently truckless
Old 03-25-2011, 06:20 AM   #18
redbaron69
redbaron69's Avatar
thanks for the pics , i will pass
Old 03-25-2011, 11:50 AM   #19
Fesser
Fesser's Avatar
Eric, money sent for the fan and the column. Thanks. Frank
Old 03-31-2011, 12:09 PM   #20
usmcchevy
usmcchevy's Avatar
Got the wheel today. MUCH better condition than I expected! Thanks!
Build thread
LSx Swap FAQ index
Old 03-31-2011, 05:46 PM   #21
RCbowtie69
RCbowtie69's Avatar
How about the 650 Holley & what the number on it ?
RCbowtie69 is offline   Reply With Quote
Old 03-31-2011, 09:28 PM   #22
67-1sttimer
67-1sttimer's Avatar
Do you still have the gas pedal with what ever hardware mounts it to the rod? Thanks Chris.
67-1sttimer is offline   Reply With Quote
Old 04-01-2011, 12:01 AM   #23
Fesser
Fesser's Avatar
Got the fan and column. Thanks much. Frank
Old 04-01-2011, 03:12 AM   #24
redhead69
fugedaboutit
redhead69's Avatar
Yes still available.. I checked it out and its a 600cfm.. list number 9834
Still available and only have the pedal itself
Currently truckless
Old 04-01-2011, 03:14 AM   #25
redhead69
fugedaboutit
redhead69's Avatar
Glad your happy with it!
Good deal! Thanks
Currently truckless
