Old 03-24-2011, 11:18 PM   #1
Project77
383 Stroker Vs. 454 Big Block
i was wondering what would be best for my truck which one is faster and has more get up and go and what kind of transmission and carberator would go best with the engine that meets my needs. i know im thinking a little ahead of my ball game but for future plans id like to start finding this stuff out sooner rather than later. and before i put a motor in the truck i will upgrade everything else such as: Tires, rims, brakes so i can make sure i have maximum performance )))
current truck information:
77 chevy silverado
regular 350 engine
regular 350 tranny
tire rims and brakes they all suck but ill fix it
just let me know what you would go with and why
Project77 is offline   Reply With Quote
Old 03-24-2011, 11:47 PM   #2
texasfunk
texasfunk's Avatar
Re: 383 Stroker Vs. 454 Big Block
There are ALOT of things to consider...a 383 can be built to blow a 454 equipped trucks doors off. And vice-versa. Depends on how much you want to spend. Since you already have a 350 a 383 swap is simple. Putting a BBC is not much different but you have to change more than you think..again it's all personal preference. My 502 equipped 81 will blow the doors off my 383 elcamino..but my old 383 equipped 82 would smoke the 502....also had double the money in it
texasfunk is offline   Reply With Quote
Old 03-25-2011, 12:00 AM   #3
my4by2
my4by2's Avatar
He's right - if you've already got a good core 350, then just go with a 383 - you can spend more on the internals due to what you'll save not having to buy the parts & core for the 454 swap. Only way I'd go 454 over the small block is if it were gonna be a pure tow rig just for that extra bottom end low RPM torque the big block has. You'll love the way a 383 puts ya back in the seat I guarantee it!!!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 03-25-2011, 12:08 AM   #4
mfwcar11
mfwcar11's Avatar
i guess its all in what u want? i'm going with a 454 just 4 the wow factor.
68 chevy swd fleetside LT1/700R/under construction
72 chevy swb fleetside sb400/400 trans
73 chevy swb fleetside bb454/400 trans 2inch drop spindles 4bar c notch and airbaged/Under construction
07 GMC HD Durmax
Marshall Weaver
mfwcar11 is offline   Reply With Quote
Old 03-25-2011, 12:08 AM   #5
von guido
von guido's Avatar
umm,you really think there is a comparison between a bbc and sbc? you have to build a radicle street sbc to get 500 rwhp and a bbc on the same power level would be MILD. I have a 30.1 inch rear tire with a 3.08 gear and with a MILD 454 I can flash the convertor at 40 and break the rear loose...and my cam is right @.500 lift so VERY tame for a bbc.
officer,we weren't racing.. he was merely pacing me.
von guido is offline   Reply With Quote
Old 03-25-2011, 12:18 AM   #6
texasfunk
texasfunk's Avatar
Off topic but the truck in your avatar=amazing! Really makes me want to get started on my 79!
Old 03-25-2011, 01:02 AM   #7
von guido
von guido's Avatar
I appreciate that
Old 03-25-2011, 03:10 AM   #8
my4by2
my4by2's Avatar
Ok, so how many people with "daily driver" vehicles have true 500RWHP numbers??? Gimme a break.... Sure you're gonna make more power with the 454 - no replacement for displacement as they say. But given he's talking about a street driven vehicle that already has the SBC installed he'd be plenty happy (and have more money left) with a mild 383 engine. Anything over 300RWHP for a street driven vehicle is going to feel GREAT & with the 383 he'll have gobs of torque down low to make the truck really pick up off the line. Besides "breaking the rear loose" might be fun in an empty parking lot, but on the street in a light rear-ended pickup (especially with posi or in the rain) it can get just a little hairy!!!
And NEVER forget the trade off of fuel mileage between the 454 & SBC - it takes more fuel to fill that large a bore & stroke without question!!!
But, just my feelings on it.
Old 03-25-2011, 03:13 AM   #9
my4by2
my4by2's Avatar
Will definitely concede this point - a well dressed 454 looks WAY better inside that large engine compartment in comparison with the SBC!!! But on the flip side, it's much easier to get in there & work on a SBC - so it's a toss up I guess.
Old 03-25-2011, 05:15 AM   #10
dos0711
dos0711's Avatar
I vote for the big block!
dos0711 is offline   Reply With Quote
Old 03-25-2011, 05:18 AM   #11
Redcap
No replacement for displacement.
Redcap is offline   Reply With Quote
Old 03-25-2011, 06:11 AM   #12
Pop's C-10
Pop's C-10's Avatar
Find a good roller cam block & gather parts as money allows...
Pop's C-10 is offline   Reply With Quote
Old 03-25-2011, 07:05 AM   #13
BigBlocksRule
If you're gonna stroke the small block, stroke the big block to make it a real apples-to-apples comparison.
Great thing about a big block is that you can make massive power with production pieces - large ovals for a strong street engine, rectangular ports for all-out and higher rpm power. Plenty of 468's running 10's and faster with factory parts. It generally takes some port work on factory castings, mind you, but it can be done.
A well-built big block will pass anything...but a gas pump
BigBlocksRule is offline   Reply With Quote
Old 03-25-2011, 07:19 AM   #14
b454rat
Big block, everyone has a small block.
I'll give yah an idea on fuel economy. My old 84 1/2t 4wd had a 350, stock but ran good. Auto tranny, killer 2.73 gears, and 31" tires. Was a dog.
Swapped in a rebuilt stock 454 with headers, 4-speed, 3/4t's with 4.10s and 35s. Of course I had a lot more power, AND GOT BETTER GAS MILEAGE. I drove this truck almost every day. I drove this more than the '08 Tundra that was my dad's.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 03-25-2011, 07:43 AM   #15
jasonroman
jasonroman's Avatar
forgive the stupid question from a guy who knows nothing....
383 comes from beefing up a 350?
if so, this comes by buying add ons. or pulling the motor and sending it to a shop?
jasonroman is offline   Reply With Quote
Old 03-25-2011, 07:46 AM   #16
my4by2
my4by2's Avatar
Well with 31" tires & 2.73 gears it's no surprise the truck was a dog.... You should'a had at least 3.73's in there - 4.10's if you had overdrive. The small block - depending on how you had it built, what intake you had & all that - needs to be in a certain RPM range to work best. That combo wouldn't have ever been there... When you did your trans & gears swaps you probably picked up as much as improvement as anywhere - had you done those swaps with the small block it would'a been night & day as well.
Look, I am not saying that the SBC is the end all to all questions & have had my share of BBC's as well & loved them. The guy that asked the questions already has a small block in his truck. I just feel it'd be easier for him to build it up to a 383 - cost wise & time wise. The small block is WAY cheaper to build - hands down! He would need to get a core big block, accessory mounts, headers - everything to do a swap in it!
And for the apples-to-apples comparison spoken of earlier - how about you do a parts list for exact brand items for each engine & let me know how much each comes to - guarantee that the BBC is gonna run a LOT more - especially since he now would have to buy a core.
Like I said before though, if he's gonna tow a great deal - build the big block no doubt! If it's a street truck, then in my mind a mild built 383 would be perfect.
Old 03-25-2011, 07:50 AM   #17
justinburnett
justinburnett's Avatar
BAsically taking a 350 and increasing the stroke by putting a modified 400sbc crank in. Someone will doubtless expand on this, but from my understanding that's the general idea. Look up "build 383" on Google.
As far as cost goes, I just did a rebuild on a 400 and the parts cost easily double what it would have been for
A 350. I don't even want to know what a 454 would cost.
[sizea=1]Posted via Mobile Device[/size]
Last edited by justinburnett; 03-25-2011 at 07:54 AM. Reason: cause I felt like it
justinburnett is offline   Reply With Quote
Old 03-25-2011, 09:07 AM   #18
b454rat
I also forgot that I swapped the 3/4 tons with the 410s and 35s before I did the 454/4-speed, still was better mileage and drivable. Sounded 10 times better too.
Here is a cheasy vid of it...
Old 03-25-2011, 11:18 AM   #19
jrcaprai
I had a 383 that dynoed at 430 HP and 465 Ft-lbs, it was not horribly expensive.
it had good parts in it, but only had a flat tappet hydraulic cam in it... it ran high 12's
I used a scat rotating assy with 5.7 inch rods, flat top pistons, Dart 200cc Pro 1 heads
in my opinion, if you are going to build an engine up to about 550 HP go with a Small block. if you are going to build something more than 550HP do a big block....
My current engine is a 408 Small block 550 HP... 500HP 383's are really easy these days
I am planning my next engine, which should be about 700 HP and it will be a BBC. 496 or 540
Don't forget about the weight advantage of a small block...
Chevy big block V8 685
Chevy small block V8 575
Chevy small block with Alum Heads 525
jrcaprai is offline   Reply With Quote
Old 03-25-2011, 11:27 AM   #20
BigBlocksRule
^ sound advice.
Big block with aluminum heads: 585lbs
All aluminum LS = featherweight!
Old 03-25-2011, 11:28 AM   #21
BigBlocksRule
Why did your 400 parts cost double what a 350 was? Small block pistons are all the same price as are rods, same with a new crank. Machine work is all the same as well...
Old 03-25-2011, 11:47 AM   #22
Cherub
Cherub's Avatar
I didnt read the other post so ill just comment to the original post.
Before you start modifing i would ask yourself what your end goal is. How much you have to spend. Then work tward that goal.
Both platforms are good but have thier inherant limitations, pros and cons. Reading up on the characteristics of both, then decide which fits your needs the best.
I hope that helps you decide,
Good luck
Cherub is offline   Reply With Quote
Old 03-25-2011, 12:26 PM   #23
pockets
pockets's Avatar
500 rwhp is not mild in a bbc. that equates to approximately 650-700 hp at the crank. Now it is easy to build that with a bbc and it will be milder than a comparative hp sbc, but it isn't exactly "mild". That is a very healthy motor indeed.
I do agree with pretty much with jrcaprai. If you are going to 500-550, a small block is fairly easy to do. Other than visual factor, a 500 hp bbc is almost a waste these days; on funds, fuel and the cubes that motor can provide. over 500, and the bbc really shines.
My 383, as spec'd in the Aug. 2010 issues of super chevy, puts out 480hp and 495ftlbs. I too used a scat bottom end but with AFR 195 heads and a flat tappet cam. With a little more cam (mine is a .490 lift) or even a roller, it would easily go over 500hp.
The other route would be an LS or LQ motor. With their heads, they can do 550-600 hp as easy as a BBC, if not easier. Of course there are other costs associated with swapping in one of those.
Project Bad Karma
pockets is offline   Reply With Quote
Old 03-25-2011, 01:54 PM   #24
jrcaprai
X2
My 408 was not double what my 383 was... and I went full roller on the 408, which the 383 was not
Old 03-25-2011, 01:56 PM   #25
jrcaprai
Originally Posted by pockets View Post
500 rwhp i
What Cam do you have in that 383 ?
